Rb26 complete head with covers ect... $1600ono
Eoi rb26 split dump pipes 400 plus swap for standard I think they are
Eoi r32 Gtr high flowed n1 turbos like new $1000
Rb26 virgin block $400
Rb26 fuel rail $40
R32 Gtr gtst dash small bubble 80
Rb26 sump complete with diff $200
Rb26 pistons $80
Rb26 rods $100
Rb26 crank in good condition come out of running car $300
Rb26 intake complete intake side includes plenum throttles bodies and everything up to the head and under plenum $450
Rb26 water pump x2 both good condition $30
Rb26 coil packs come from running car $100
R32 Gtr coil pack harness $60
Rb26 coil pack cover $60
R32 Gtr ecu $80
Rb26 stock oil cooler
Rb26 oil pump $50
Rb26 air con pump $80
Rb26 power steering pump $50
Rb26 alternator $60
Rb26 turbo manifolds $80
Rb26 turbo oil and water steel lines $50
Rb26 twin turbo pipe $40
R32 Gtr standard suspension $100
R32 Gtr wheels and falken tyres $650
Chrome gear knob nismo style$10
Rb26 cas 80
Rb26 alloy engine brackets
Rb26 engine mounts used but appear to be ok 20
Rb26 knock sensors 40
Rb26 knock sensor loom 20
R32 Gtr radiator shroud 30
Location gold coast but happy to post most things
Parts will be available in a couple of days I'll let you know about the crank wether its long snout or not or you could just buy a collar for it
Edited by toy515
should have pics today of the crank, havnt really got the time to take it down ect.. its come out of a running car also not a motor that has spun a bearing like most.
and freight would be 50 due to the weight
cheers
cheers
thanks for the reply.
going to have to decline.
I've seen twisted cranks come out of ok motors, hence the reason I wanted it checked.
Glws.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
