Hi all,
I'm posting this here and in the 'SA' forum in case there are any non-SA people who may have had experianece with SA instrument specialists.
I've just bought an R32 GT-R and there's a minor problem with the speedo. Has anyone had good work done on R32 gauges in Adelaide? If you have, can you please let me know who you would recommend?
Cheers!
Mike
Well, after starting (or any reasonable time stationary) the speedo reads 1.5-2 times the speed that my GPS speed readout gives. Forexample, yesterday in 110km/h traffic the needle was past the 180km/hr limit of the gauge. After a time the difference diminishes, and in some instances it returns to the correct reading. Today for example, it was showing 60km/h when the GPS was showing 60km/h amongst urban traffic.
The tacho and odometer are running correctly though.
It's the stock cluster and it's pretty steady actually. None of the symptoms associated with damaged cables that I can identify by searching these forums.
I popped into Gauge Works in Adelaide yesterday. They're pretty confident that they can sort it. I'll probably get them to fix it and I'll post the results in the forums to add to the knowledge base.
having issues with my cluster as well, speedo reads faster than the speed im actually doing (std sized wheels/diff etc). . .could you post what you end up paying for the work done please?.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
