Hi everyone:
Anyone had their RPM gauge on their dash go CRAZY for no reason even if the car is comfortably sitting idle ???
Anyone know possible causes or someone in S/East Vic able to check out safely?
Should I be concerned? It's just happened over the last 2 days. Flies all over the place like i've just driven into Area51
Thanks :unsure:
https://www.sau.com.au/forums/topic/407386-rpm-gauge-reading-needle-goes-crazy/
Ah really??!!.. bugger! so it's possibly on its way out the door.. you think ebay have these avail?
Ironic really this happened as only recently talked about changing dash lights so I could get something different..
Better find someone who can help.
Anyone know any Auto Elec's in South East Melb who are safe/reliable with Sky probs like this? Or if i provide the cluster, they can fit for me?
Sounds like its complicated to do.. not sure. :(
My mates 33 does the same thing. Normally just stays facing down lol. But once he is driving it just goes everywhere.
LOL yep, must be a "trait' with these, but thats what mine does too! I'm calling it abduction. Its very X-Files. LOL :nuke::ninja:
loose connection / dry solder joints...
it will get worse, then will eventually stop working..
as people have said, cluster swap would be the easiest option..
Hmmm I see... Thanks for the feedback.. Am keeping eyes peeled for a 2nd hand job on ebay etc. Not in a huge rush as want to change globes anyway when I do it. Sounds the simple option for me anyway as i'm still pretty green. Easy to forget these cars are around 15 yrs old...
My r32 does this too. I dont know what causes it but it does stop on mine after a bit of driving. Dont really look at it much so im not too bothered at the moment.
Maybe you could bring monster tacho craze back in? :P
HA. You into monsters? I never did catch on to the phase. I'm thinking a pod of 3?
This is a common fault and the fix instructions are available below. Might be worth a go before replacing the cluster.
http://www.skylinesa...acho-r33-maybe/
Hope this helps.
Edited by iwanta34gtr
I had this issue, replaced cluster with the one out of parts car and then the speedo wouldn't go above 60kmh. Swapped out the speedo and now I've got one perfect cluster and one fubar one :P
Could maybe sell the tacho component to the OP if required?
Hope this helps.
Fantastic. Thanks so much.. !!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
