Hi everyone:
Anyone had their RPM gauge on their dash go CRAZY for no reason even if the car is comfortably sitting idle ???
Anyone know possible causes or someone in S/East Vic able to check out safely?
Should I be concerned? It's just happened over the last 2 days. Flies all over the place like i've just driven into Area51
Thanks :unsure:
https://www.sau.com.au/forums/topic/407386-rpm-gauge-reading-needle-goes-crazy/
Ah really??!!.. bugger! so it's possibly on its way out the door.. you think ebay have these avail?
Ironic really this happened as only recently talked about changing dash lights so I could get something different..
Better find someone who can help.
Anyone know any Auto Elec's in South East Melb who are safe/reliable with Sky probs like this? Or if i provide the cluster, they can fit for me?
Sounds like its complicated to do.. not sure. :(
My mates 33 does the same thing. Normally just stays facing down lol. But once he is driving it just goes everywhere.
LOL yep, must be a "trait' with these, but thats what mine does too! I'm calling it abduction. Its very X-Files. LOL :nuke::ninja:
loose connection / dry solder joints...
it will get worse, then will eventually stop working..
as people have said, cluster swap would be the easiest option..
Hmmm I see... Thanks for the feedback.. Am keeping eyes peeled for a 2nd hand job on ebay etc. Not in a huge rush as want to change globes anyway when I do it. Sounds the simple option for me anyway as i'm still pretty green. Easy to forget these cars are around 15 yrs old...
My r32 does this too. I dont know what causes it but it does stop on mine after a bit of driving. Dont really look at it much so im not too bothered at the moment.
Maybe you could bring monster tacho craze back in? :P
HA. You into monsters? I never did catch on to the phase. I'm thinking a pod of 3?
This is a common fault and the fix instructions are available below. Might be worth a go before replacing the cluster.
http://www.skylinesa...acho-r33-maybe/
Hope this helps.
Edited by iwanta34gtr
I had this issue, replaced cluster with the one out of parts car and then the speedo wouldn't go above 60kmh. Swapped out the speedo and now I've got one perfect cluster and one fubar one :P
Could maybe sell the tacho component to the OP if required?
Hope this helps.
Fantastic. Thanks so much.. !!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
