  • Replies 49
I have a budget of $4000. I'm thinking freshen the head up with new valve springs while its off, anything else i should do it? And with the RB30 bottom end I have here just leave it as it is. After all I have a gq I'm not chasing 300rwk. Then say $800 on an ecu? I'd say $4000 should be plenty. I'll be keeping stock turbo for now. What type of ecu should i get so I can keep an eye out for a 2nd handy?
Cheers
Your budget doesn't really allow for anything decent. I would buy a Z32 ECU and Nistune it. Unless you have a Neo ECU which can be chipped.
Forget about valve springs. Factory ones are fine for what you are doing.
How so? I'm not touching the rb30 bottom end. So where is this $4000 going? I thought a $1000 for an ecu is about right? Especially if I go second hand. I'm keeping stock turbo for now.
Because even a decent ECU is $1500 second hand. The cheap units can 'do' the job but when you realize there is no stepper motor control or inconsistent firmware faults etc. or the car drives very poorly because of bad fuel or timing control, the car won't be fun to drive anymore. You will try to apply minimal throttle for tough situations but it will jerk and carry on because it doesn't have the finer tuning details that other high end ECUs have.
There is also the issue of getting water into plug in boards so pretty much rule out a microtech plug in. You would be better off with a rewire in that regard and then you've chewed up your 4k inc tuning already and haven't even touched the engine.
That's why I suggested a Nistune.
Thanks for the reply mate I now realise you are correct. Z32 ECU and Nistune it is then. Can i use the standard AFM? I thought i cauld nistune a rb25 ecu. At the end of the day it's not a drag car haha. Sourced a good rb30 bottom end that I'm picking up today it's a s2 block which is good. The car gets revved so thats why I thought new heavy duty valve springs would be a good idea. Tomorow all the interior gets put back in the car as its dried out from getting submerged! Lol
Cheers Zac
I'll get flamed for saying this but
Get a microtech, don't worry about what these guys on here ssy about them cause they are biased, it will run ur engine fine, cheap to tune($250 for ur initial and about $120 for touch up tunes) they are simple so less to go wrong! I've had 3 cars with microtechs snd never had a drama, why get a ecu with all the bells and whistles when all u need is for it to run ur car! They are easy to wire too, if u need help i could do it for u depending on where u are.
Just my 2 cents
Good luck with the budget, I have just finished this process. firstly you will loose your top end power with the stock turbo and if thats all the money you have to get it back on the road you will need a pushbike until you save some more. The end result is very worth it as the rb30 bottom end power is needed to get the Patrol moving before lunch.
Enjoy
Steve
Just my 2 cents
Microtech are great. They do exactly what they are supposed to do and do it reliably and easily.
They are ass to tune, don't do A LOT of things that modern cars need them to do, don't have ANY functionality other than fuel and timing control and even then the timing control is f**kED. If he buys one second hand, it will prob cost about $800? then he's going to need to do a full wire in (enter mr problems)
That will add more cost. Then, depending on his capabilities as an auto electrician (and even then not many can wire an aftermarket ECU properly) it may have more problems due to insufficient power etc.
If you're going to suggest a plug in, don't bother, the ECU board is out in the open, unsealed. This is a 4wd that is likely to be submerged regularly. Too risky.
Like I said though, it will do its job.....just not as well as others. A Nistune will definitely do it better and cheaper
Yeah i like the idea of the nistune, i cant find any z32 ecus? Should i search for 300zx ecus? A manual one is what i need correct?
I thought $4000 would be plenty considering its not gonna cost me anything for the motor. As i got the rb30 for free pretty much and i already have the rb25 head. Well come on i dnt need the car on the road so what turbo should i get?? Keeping in mind everything i do has to pass a roadworthy in VIC as the car is not currently registered.
BTW this thing flew for a 4wd it would be on par with my mums v6 commodore(yeah i know its a shitty ecotec, but this is a 4wd!)
Dude! Did you just make a speed comparison with a v6 commodore? SHAME ON YOU!!
Nah seriously I had to do a clutch on a cruiser with a 2JZ......no shit.
It made 350hp at the wheels I think. Was pretty funny to drive.
Z32 is a 300zx. Z32 is the model. You need a manual one of those. Auto one will work too I think but don't quote me on that. You'd need to speak to Matt at Nistune to ask that one.
With a turbo upgrade and the Nistune inc tuning and a few other bits and pieces I'd say you'd chew up $3k pretty fast.
Yeah well leave the turbo out of the $4000 because it can be put on last, i dnt need the car on the road so if it sits there for a month or 2 longer while i save up some cash for a decent turbo i dont mind. Okays well i guess ill search around for one, ill get a manual one just to be sure saves the headache!
Im gonna start getting a few parts together
Okay thanks for that mate. I'll look out for one. Didn't get around to picking up the block last night so will do it today and then pull my rb25 block out. It's still attached to the gearbox. I gotta figure out what starter motor fits the rd28 flywheel.
I'll keep the thread updated and I'll post some pics. There's a couple when I drowned it. Cars fully underwater and I'm standing on the roof! Haha
Cheers
Just a question I've read up a bit about what I gotta do to match the head with the 30 block, it seems fairly complicated, is it? have a series 1 head, I think it makes things a bit easier?
Cheers
A couple of mates are telling me not to stuff around with the 30DET and just stay 25DET. I want to do this for the torque, as I am in a 4wd. Does the rb30DET have considerably more torque? Also I know you can engineer rb25s in my patrol but can I engineer an rb30/25? Will they just call it an rb30?
Thanks guys
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
