  • Replies 49
I have a budget of $4000. I'm thinking freshen the head up with new valve springs while its off, anything else i should do it? And with the RB30 bottom end I have here just leave it as it is. After all I have a gq I'm not chasing 300rwk. Then say $800 on an ecu? I'd say $4000 should be plenty. I'll be keeping stock turbo for now. What type of ecu should i get so I can keep an eye out for a 2nd handy?
Cheers
Your budget doesn't really allow for anything decent. I would buy a Z32 ECU and Nistune it. Unless you have a Neo ECU which can be chipped.
Forget about valve springs. Factory ones are fine for what you are doing.
How so? I'm not touching the rb30 bottom end. So where is this $4000 going? I thought a $1000 for an ecu is about right? Especially if I go second hand. I'm keeping stock turbo for now.
Because even a decent ECU is $1500 second hand. The cheap units can 'do' the job but when you realize there is no stepper motor control or inconsistent firmware faults etc. or the car drives very poorly because of bad fuel or timing control, the car won't be fun to drive anymore. You will try to apply minimal throttle for tough situations but it will jerk and carry on because it doesn't have the finer tuning details that other high end ECUs have.
There is also the issue of getting water into plug in boards so pretty much rule out a microtech plug in. You would be better off with a rewire in that regard and then you've chewed up your 4k inc tuning already and haven't even touched the engine.
That's why I suggested a Nistune.
Thanks for the reply mate I now realise you are correct. Z32 ECU and Nistune it is then. Can i use the standard AFM? I thought i cauld nistune a rb25 ecu. At the end of the day it's not a drag car haha. Sourced a good rb30 bottom end that I'm picking up today it's a s2 block which is good. The car gets revved so thats why I thought new heavy duty valve springs would be a good idea. Tomorow all the interior gets put back in the car as its dried out from getting submerged! Lol
Cheers Zac
I'll get flamed for saying this but
Get a microtech, don't worry about what these guys on here ssy about them cause they are biased, it will run ur engine fine, cheap to tune($250 for ur initial and about $120 for touch up tunes) they are simple so less to go wrong! I've had 3 cars with microtechs snd never had a drama, why get a ecu with all the bells and whistles when all u need is for it to run ur car! They are easy to wire too, if u need help i could do it for u depending on where u are.
Just my 2 cents
Good luck with the budget, I have just finished this process. firstly you will loose your top end power with the stock turbo and if thats all the money you have to get it back on the road you will need a pushbike until you save some more. The end result is very worth it as the rb30 bottom end power is needed to get the Patrol moving before lunch.
Enjoy
Steve
Just my 2 cents
Microtech are great. They do exactly what they are supposed to do and do it reliably and easily.
They are ass to tune, don't do A LOT of things that modern cars need them to do, don't have ANY functionality other than fuel and timing control and even then the timing control is f**kED. If he buys one second hand, it will prob cost about $800? then he's going to need to do a full wire in (enter mr problems)
That will add more cost. Then, depending on his capabilities as an auto electrician (and even then not many can wire an aftermarket ECU properly) it may have more problems due to insufficient power etc.
If you're going to suggest a plug in, don't bother, the ECU board is out in the open, unsealed. This is a 4wd that is likely to be submerged regularly. Too risky.
Like I said though, it will do its job.....just not as well as others. A Nistune will definitely do it better and cheaper
Yeah i like the idea of the nistune, i cant find any z32 ecus? Should i search for 300zx ecus? A manual one is what i need correct?
I thought $4000 would be plenty considering its not gonna cost me anything for the motor. As i got the rb30 for free pretty much and i already have the rb25 head. Well come on i dnt need the car on the road so what turbo should i get?? Keeping in mind everything i do has to pass a roadworthy in VIC as the car is not currently registered.
BTW this thing flew for a 4wd it would be on par with my mums v6 commodore(yeah i know its a shitty ecotec, but this is a 4wd!)
Dude! Did you just make a speed comparison with a v6 commodore? SHAME ON YOU!!
Nah seriously I had to do a clutch on a cruiser with a 2JZ......no shit.
It made 350hp at the wheels I think. Was pretty funny to drive.
Z32 is a 300zx. Z32 is the model. You need a manual one of those. Auto one will work too I think but don't quote me on that. You'd need to speak to Matt at Nistune to ask that one.
With a turbo upgrade and the Nistune inc tuning and a few other bits and pieces I'd say you'd chew up $3k pretty fast.
Yeah well leave the turbo out of the $4000 because it can be put on last, i dnt need the car on the road so if it sits there for a month or 2 longer while i save up some cash for a decent turbo i dont mind. Okays well i guess ill search around for one, ill get a manual one just to be sure saves the headache!
Im gonna start getting a few parts together
Okay thanks for that mate. I'll look out for one. Didn't get around to picking up the block last night so will do it today and then pull my rb25 block out. It's still attached to the gearbox. I gotta figure out what starter motor fits the rd28 flywheel.
I'll keep the thread updated and I'll post some pics. There's a couple when I drowned it. Cars fully underwater and I'm standing on the roof! Haha
Cheers
Just a question I've read up a bit about what I gotta do to match the head with the 30 block, it seems fairly complicated, is it? have a series 1 head, I think it makes things a bit easier?
Cheers
A couple of mates are telling me not to stuff around with the 30DET and just stay 25DET. I want to do this for the torque, as I am in a 4wd. Does the rb30DET have considerably more torque? Also I know you can engineer rb25s in my patrol but can I engineer an rb30/25? Will they just call it an rb30?
Thanks guys
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
