Does anyone know where nismo-style R34 gtr rear diffuser fins can be bought online? I've seen the genuine nismo and hasemi ones floating aorund but theyre worth bucketloads :I I also saw a few months ago one of the guys on gtroc UK selling the copies in CF for 300 pounds, but he no longer does. Any pointers are much appreciated!
https://www.sau.com.au/forums/topic/407447-r34-gtr-diffuser-fins/
These guys only supply genuine NISMO fins, I was after the look alike nismo-style ones. Theyre bloody hard to find :/
Or give Import Revolution a call.
A friend of mine works there or speak to the owner Nuwan.
I was told they can get in genuine parts a very good prices.
Awesome thanks mate. I'll give them a buzz tomorrow. And Simon, the nismo GT diffuser fins are larger and look tougher than the factory OEM ones
All good!
Let me know how you go, as I am wanting to get some genuine parts off from them.
Another option is try Team Jetspeed or better yet Top Stage.
I think Top Stage is what you might be after.
  • 4 weeks later...
No luck. Got PMd by another member who told me he was in the process of making some but that theyd be much more than the 300 i was expecting them to be around. Contacted the guys in the UK, they said they can get me the hasemi ones but for about 750 AUD :O
  • 2 months later...
im on the hunt for a diffuser as mine didnt come with one but will defintly put bigger fins. you got good taste bro they look amazing
Someone trace one and send it to me
I'll make some out of carbon for ya cheap as chips
Diffuser for gtt in carbon as well but depends on muffler setup for cutouts
Gtr diffuser as well if I can get a gtr test fit up car ?
Would be a fraction of the cost could be Kevlar and carbon so it won't break so easy and won't scuff
if you can make me one il buy it asap. as long as they dont flap around when driving? very keen (oh and bigger fins ofcourse hehe)
Flap around lol I can display the strength of two layers of carbon and a ball peen hammer attack
It doesn't mark it or crack or at all , it doesn't flex even with my fat ass standing on it
With Kevlar it's even stronger and abrasive crack resistant ( the Kevlar is black weave)
Also have blue and black carbon Kevlar weave
Trace one out and take some close ups of it
Prob cost about 150-200 for 4 depending on the size and finish , gloss or dry , can embed a washer around bolt holes so it can't pull out as well
The more I do the cheaper it gets of course
And no it's not a biz just a hobby
get crackin carbon34 i want one haha jks
start a group buy or something?
but these large fins got to be hektic lmao
Somebody trace one and measure one
I have the carbon and Kevlar already
if you want a test one made shoot me the info and who can test fit one ?
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
