If you two don't knock off the whoring in threads outside of the wasteland - you are both going to see some resulting action being taken that you probably won't like.
Enough is enough guys. People have had enough of it.
2001 V-spec 2 HKS cam gears , nismo twin plate clutch ,HKS front pipe , Veilside Titanium 3.5inch exhaust , Apexi power fc ,Apexi pod filters , HKS hypermax 2 coilovers, ACPT carbon drive shaft thats about it i think stock engine turbos and fuel system, it had 260awkw @ 15psi ran a 12.2 @116mph with stock rims with 245 tyres that were way past their use by date were as hard as a rock best 60ft time i could get was 1.98sec this was done at the townsville drag strip possibly the worst prepped track in australia
Edited by gtr13
no offence and I debated with myself for a while before posting this( waits for some noob to edit quote that line), but it the way you are driving the car, I have an 11.13 @ 123 mph in my 32, and 11.8 @ 118mph in the 34 ( I have only dragged the 34 once on someone elses setup ) so a 122mph should be a mid 11, read the how to launch your GTR thread and practice
A mate ran a 12.3 @ 110 with his R34 vspec. Mods at the time were a twin plate exedy clutch, power fc, AVCR and a street tune to 1kg/cm boost. Estimated to be about 230kw atw. It was in the middle of summer and his tyres were shagged as well I believe.
this sounds impossible to be honest,
people are saying they just rev dumped first which i did and smacked every gear
i started the "how to launch your gtr" thread haha its good getting everyones opinions
Well its not. He was consistent and ran 12.3's repeatadly. I know his reaction times are always good too, and he is pretty brutal with the car.
I left out that he has an 80mm titanium exhaust on it too. At the time I'm pretty sure thats it for mods
I've read that 11's are possible on stock low mounts if your willing to lean on them to the point of breakage.
Turns out that it was 111mph too:
I thought side step and dumping were the same thing
Side steo being - you move your foot to the left of the clutch resulting in stepping off instantly
Dumping - you lift your foot straight off
Besides, all you guys averaging 1.9 60' times need to get a better launch. Should be getting 1.6 60'
This guy knows stuff!!!
And I keep telling people it's all in the first few seconds of getting outta the hole that will seperate you from that average time to that great time.
I'm .1 off a 1.6 :D
if i can hear correctly.. hes ranging from 12.3 to 12.7
i can see hes trying to side step instead of dumping which was causing smoke
In other runs last year he was doing 12.3 to 12.4.
The more recent youtube footage taken this year is slower due to problems with the car not running right. An intermittent ecu fault would make his tune go rich and drop ignition to cylinders occasionally.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
