Hello, this may have been asked a million times before, if so, sorry.
Trying to match my paint after fixing some rust on the R33 Skyline in QM1 Polar White? the paint i got looks more yellowish then it needs to be.
Has anyone had any luck or trouble before with trying to match up the paint. I need to find the right paint mix. Auotbarn dont have anything to mix and match.
You can see here in the image its quite different. Any help will be rewarded with a virtual potato...
https://www.sau.com.au/forums/topic/407491-matching-paint-on-white-r33-help/
That looks like the holden version , serious they have a cross reference to it and the lazy person didnt ask enough questions
I ran across it twice now when i needed a rattle can to touch up my wheels the day before a show
Two places crossed it to some holden paint code ( my car is also qm1 )
It can also be the primer behind it is different ?
Bet on the first one holden colour
Autobarn has 2 different QM1. One being more darker and one being more, well, whiter. I've got both of them and haven't had any luck in having perfect match. Autobarn's database has QM1 Polar white and QM1 P(some long name no one knows how to say in english).
My QM1 compared to Terry's N1 which is also QM1, seems to differ as well. His one being bit more creamy and my one being bit more pure white. I believe there is something more to it than just "QM1". Also a member on here apparently bought the wrong touch up "QT1", but his feedback was a perfect match.
I'd say do a full respray on your bar and keep the mixture for future reference. I'm in the same boat as you, trying to touch up my front and rear bar, but looks like a full respray of the bar will be best way to go about it. Oh and of course try to match it with your car as close as you can.
The guy showed me both the qm1 at autobarn both had a tiny shade of yellow. Also I was just thinking before that the colour is very similar to a white Holden commodore I used to own maybe I can try that same colour to see if it's matches.
There are like 3 types of QM1 for nissan skyline!!
It sucks.
How about we all get 500ml of QM1 > meet for a BBQ > mix them all together > go home happy with about 495ml each?
Srsly, my painter had to adjust the QM1 that he made up because he'd learnt before that it varies.
He sprayed samples of QM1 on test cards and compared the test cards to my existing panels.
He said that Nissan has been making QM1 for decades.
Autobarn lol
They kept trying to sell me the "qm1" crossmatched from the book and i know the paint code for the rattle cans from duplicilour comes up as holden sedan not nissan qm1 the pj number is different they had to refund my money cause it wasnt even close to polar white
My advice go to a car paint store the other guys are muppets at paint matching
My money is on holden colour or early generic nissan (70-80's) which had more yellow in it
Also r34 like mine had super hard paint code qm1 same colour just different mix of clear its worthless , someday I'll grind it back to metal and redo the whole car , its extremely nice when its done but damn its a lot of work
Thanks for the help everyone. If anyone else does any minor rust repairs here is what i did, i went to KGP here in Emu Plains and they matched the paint exactly in an aerosol can. And i managed to finnish the rust repair with a perfect match. So bottom line never go to Autobarn for paint help :D
here is the result of the work:
Pre Rust:
prerust.jpg?t=1346037979
Post Rust
fixed.jpg?t=1346037644
Edited by GetToDaChopa
Bit off topic.
My R34 has QT1 colour. It's metalic pearl white (silverish/white colour if you get my drift) - You can buy QT1 from Infiniti USA :)
Just thought to come back and recorrect my remark about Autobarn. I used my QM1 Polar White that I got from Autobarn and it matches my panels. Just sprayed my spoiler and it was a great match. my front and rear bars need to be resprayed cause I think they a commodore white with the creamy tinge.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
