Update for future ref
Power plus touch up paint from Autobarn and other shops
Qm1 paint code = 93-00 Nissan Pj2142
this is the skyline color polar white
Qm1 paint code = 93 Nissan pj2240
Alabaster White
This is the yellowish white that Autobarn tried to sell you
  • 3 weeks later...
Thanks for the help everyone. If anyone else does any minor rust repairs here is what i did, i went to KGP here in Emu Plains and they matched the paint exactly in an aerosol can. And i managed to finnish the rust repair with a perfect match. So bottom line never go to Autobarn for paint help :D
here is the result of the work:
Pre Rust:
prerust.jpg?t=1346037979
Post Rust
fixed.jpg?t=1346037644
Well done. looks good.
Exactly what i would have done if i didn't have the tools to paint properly.
Another way to ensure it comes out perfect is to paint the area u need to then cut it back (slightly) using 2000 wet and giving it a buff to make sure it blends in with the bumper.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
