This thread is purely for the pursuit of strength in the big 3 lifts, squat, bench press and deadlift.
Its not about dieting or looking good, its about lifting more weight CORRECTLY than the guy next to you
I know the Presidents of all 3 Feds in Australia, and the State delegates, so if you want to start lifting and youre not from Vic, I can help.
I'll let you guys know I am the President of GPC in Australia, but I have also been the State delegate for CAPO, the other Fed is PA. I have close friends in all 3.
GPC has the most states under its umbrella, with only Tassie not included
As far as PL clubs and Gyms, I can steer you guys in the right direction, let me know where you live and I'll tell you the closest strength gym. If your simply looking for a health spa, just Google it as I'm not familiar with them at all.
If you want to lift in a comp, be it novice or National level, with everything in between, just ask.
If you want to bench only, there are comps that cater for you
Questions on rules, equipment, attire, where to buy, I know the distributors.
While I own and run a specific PL forum, I understand the attraction of spending "time" with others that have similar interests, thats why I'm here
Ask anything, fire away, I'll try and assist
  • Like 1
https://www.sau.com.au/forums/topic/407502-powerlifting/
Well Birds, you have to wear correct footwear in any sport, football, basketball etc
Squatting. There are 2 options and it depends on your flexibilty/technique.
The heel option is a weightlifting shoe. You can buy Do Wins or the awesome Nike Romaleos directly from Ironedge in Glen Iris, Victoria
For those that can squat deep without a heel, Chuck Taylors or the best no heel shoe is the one made by Metal. You can get them from Nick at Underground Elite, they are in Brisbane , tell him Markos sent you
Bench press, no special shoe required
Deadlift, the flatter the better, so Chucks, Metal or ballett slippers
http://www.kettlebells.com.au/store/nike-romaleos-2/
http://www.kettlebells.com.au/store/weightlifting-shoe.html
http://www.undergroundelite.com.au/Deadlift-Slippers.html
http://www.undergroundelite.com.au/Metal-Squat-Deadlift-Shoes.html
If you buy at these stores, tell them Markos from PTC sent you, there should be some discount I hope
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6498552
There are 2 types of chucks (converse all stars) - one that has a thick sole and one that is eally thin.
If you don't need the raised heel of a weight lifting shoe, you're better of getting the thin sole chucks as this allows you to use them for deadlift too and keeps you as close to the ground as possible.
I squat in heeled shoes.. the Do wins mentioned by Markos.
for deadlifts, I have a pair of Puma shoes which have like a 3mm sole so I use them.
Lifting in a regular gym will not allow the deadlift slippers.
pics..
regular chucks (obviously these come in non boot form)
Slim
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6498575
I usually sneakily do deadlifts, squats, and leg press bare-foot, though I often get in trouble haha.
I've been eager to try squats with a piece of wood or similar under my heals to see if it helps out, however it may be some time before I try this thanks to stupid injury.
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6498652
I usually lift in vans authentics, which aren't much different to chucks. But given I only squat and deadlift once a week it's probably not going to matter much
Come to think of it, I have a pair of these and they actually felt pretty good when doing deadlifts.
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6498798
Nick, hi tops are no problem, check out the Metal brand, hi top, awesome shoe
Max wears them for all 3 lifts, he likes the grip he gets on bench with them during leg drive
Thanks Tolga for the pic and more detailed explanation on Chucks
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6498825
The high tops give a feel of security/stability at the ankle too.
doubt it would actually help the squat but the tightness around your foot and ankle give a sense of stability.. much like knee sleeves. They don't give any rebound to help you squat more but the tightness and warmth they provide around the knee feel good mang.
Personal choice though.
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6499622
general rule of thumb that most strength people will say is squat 140, bench 100, dead 180 (in the US they say squat 300lbs, bench 200lbs, dead 400lbs)
That is a Novice level.
that is for single reps obviously.
From what I've seen, it is quite common for people to be able to squat 160, bench 100 and dead 180.
for the average male who is newish to lifting and is an average 5'9" and say 75-85kg.
It really is a "piece of string" question though.
I'd say that when you get to a 4 plate squat, 3 plate bench, 5 plate dead (180, 140, 220) at a body weight of 80-85kg you wouldn't come last in a comp, but you'd be closer to the bottom of the list than that top.. ask me how I know.. lol
Heel for the squat is helpful if you don't have as much flexibility in your ankle area.
if you squat with a narrow stance, you tend to have your knees going forward more which means more bending at the ankle.
a wider stance will have you sitting back more so your ankles don't bend as much.
example..
olmypic lifter style squat
Powerlifter squat.
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6500207
Thanks Tolga, answered perfectly
Ghosty, they are the Metals
I think some of the guys at PTC Brisbane have them, Ricky?
There is no entry level. At the PTC's we run novice comps to introduce lifters to the sport, like the comp Nick did on the weekend.
Everyone is different, but everyone is welcome, you dont need to be a certain strength to start. Its not cricket say, where you may end up playing C Grade etc, everyone competes together, but essentially you compete against yourself every time
https://www.sau.com.au/forums/topic/407502-powerlifting/#findComment-6500251
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
