i dont think hgh by itself would be that good, definently need it with other geasr to make it do what you want...
In regards to cycling and lifting, i know a fair few tour de france riders have giant quads which would partly be due to all the bike riding they do.
back on topic..
The worlds comp in Slovakia finished up.
The number at the end of each line is their glossbrenner score (look it up - it's a formula used to take in to account age and weight etc etc.)
Results and points of Oz team at Worlds
WOMEN
Nina 330kg @ 57.3kg - 669.83
Sussy 292.5kg @ 54.9kg - 575.99
Cami 325kg @ 69.3kg - 544.00
Tish 252.5kg @ 52.1kg - 526.88
Amanda 337.5kg @ 76.7kg - 515.03
Vicki 272.5kg @ 57.8kg - 503.69
Bec 377.5kg @ 112.3kg - 497.55kg
MEN
Ricky 847.5kg @ 107.8kg - 754.28
Scott 724.5kg @ 89.9kg - 702.04
Emad 602.5kg @ 74.2kg - 679.62
Max 650kg @ 86.4kg - 665.48
Jack 745kg @ 152.3kg - 629.96
Conor 500kg @ 81.1kg - 562.14
Dan 525kg @81.7kg - 543.90
Zach 565kg @ 144.8 - 500.08 INJURED
Spiros 525kg @ 126.6kg - 492.54 INJURED
57 new Australian records were set by those people above (records can be set for each lift or total so people can actually set up to 4 records in the one comp)
There were a whole bunch of world records set too.
Edited by TTT
Here are the Australian records...
WOMEN
56kg Junior - Tish Wasson sq95/bp45/dl112.5 - total 252.5kg
56kg Open - Sussy Kollen squat 112.5kg. Total 292.5kg
56kg masters 1 - Sussy Kollen sq112.5/bp60/dl120 - total 292.5kg
60kg open - Nina Markopoulos - deadlift 142.5kg, total 330kg
60kg masters 2 - Nina Markopoulos - squat 120kg, deadlift 142.5kg, total 330kg
60kg masters 1 - Vicki Jewson - deadlift 132.5kg
82.5kg open - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
82.5kg sub masters - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
90kg+ open Rebecca Zepackik - 157.5kg squat
90kg+ sub masters - Rebecca Zepackik - 157.5kg squat
MEN
75kg open Emad Nayef - total 602.5kg
75kg sub masters - total 602.5kg
82.5kg teen 2 - Conor Zyskowski squat 200kg
90kg junior - Max Markopoulos bench 155kg
90kg open - Scott wasson 265sq/157.5bp/302dl - 724.5kg total
110kg open - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
110kg sub masters - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
140kg masters 2 - Spiros Markopoulos 235sq/150bp/140dl - 525 total
140kg+ open Zach Turner sq 310/bp 190
140kg+ teen 2 - Zach Turner sq 310/bp 190
140kg+ open - Jack Pollard - deadlift 280kg / 745kg total
140kg+ junior - Jack Pollard sq280/bp185/dl280 - 745kg total
Equipped bnench only - 140kg+ Zach Turner 250kg - open and Teen 3
Read more: http://prorawpowerlifting.proboards.com/index.cgi?board=results&action=display&thread=1401&page=6#ixzz27M3Kw8s3WOMEN
MEN
I believe it's something that creates a lot of elastic like tension across your chest...in ways similar to a sling shot? Will let someone who actually knows confirm.
Its a shirt :). Like this one: http://www.inzernet....T_ID=08_TPL_DEN although it depends on single ply, multiply et cetera.
It completely changes the lift, I've tried one on once and could not get 120kg to go down at all, I needed more weight. The tightness is more across the back then the chest when I tested out a bench shirt, but I've never competed in one or learned to use a bench shirt correctly.
There are also squat suits...these also change the squat and allow more weight to be squatted.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
