ProRawFour will be held on Saturday November 10 at the Frankston Art Centre. I have $5000 cash and $2000 in prizes for the lifters so far. We have around 40 signed up already. As well as the Trophies, Protein and Cash that I am giving away, the winner in each of the 5 divisions will get a giant novelty cheque to keep. Come and watch if your free, its a pretty special show, a little bit Rock'nRoll. I own ProRaw so I am not bound by any Federation rules, I am a law unto myself
Lifters coming from most states, here are the top lifters from each
QLD
Odell Manuel
Alex Zerba
Jackson Murrie
Ben Bouchereau
ACT
Nathan Jones
Katie Foster
Simon Wile
NSW
Adam Roe
VIC
Laird Ross
Nina Markopoulos
Max Markopoulos
Alen Pezerovic
Jack Pollard
SA
Firas El Achkar
Matt Brunoli
Kristos Papanotis
WA
Paul Rucci
The favourites are
Super Heavy Weight (110kg+) - Odell Manuel
Heavy Weight (110kg) - Nathan Jones
Middleweight (95kg) - Matt Brunoli/Laird Ross
Lightweight (80kg) - Ben Bouchereau
Next years event, ProRawFive, is invitation only, the Top 10 lifters in each class for the year are invited, prizemoney should double
Markos I'm still thinking about entering, what are the requirements and when do enteries close?
I'm sure I can get 520kg or so... I don't have enough pride to worry about coming last lol
Will you be using the texas bar for deadlifts? I still haven't maxed that sucker!
Soft suit is a one piece tightish outfit.
kind of like what wrestlers wear or triathletes.
they don't have any carry over to helping you lift.
it's just to help the judges make a decision (makes it easy to see if you are squatting low enough or if your hips are locked out for deadlift) and it also makes for a uniform look to the sport.
The knee braces are called "knee wraps". it is a 2 - 2.5 meter, stretchy material this is wrapped around the knees.
Depending on how tight you can handle them on there, has a fairly large carry over to squats (which is the only time they are allowed to be used)
By Back brace I assume you mean a Belt. Yes it is allowed in RAW competition (as are the knee wraps) but neither is mandatory.
if you learn to use them, they both have a carry over and allow you to lift more weight.
Wrist wraps are allowed during Bench and Squats.
My lifters mainly use my Progressive Poundage Program (PPP) that I sell online for $20
Nick on here has just purchased it and is making good progress. I have it up on the walls in the gym
Its been around for about 3 years now. There are actually a few others on here who got it years ago
CS Student, Gareth, used it with great success. At only 84kg or so he squatted 210kg, benched 130kg and deadlifted 230kg from memory
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
