My lifters mainly use my Progressive Poundage Program (PPP) that I sell online for $20
Nick on here has just purchased it and is making good progress. I have it up on the walls in the gym
Its been around for about 3 years now. There are actually a few others on here who got it years ago
CS Student, Gareth, used it with great success. At only 84kg or so he squatted 210kg, benched 130kg and deadlifted 230kg from memory
Just had a quick look on PTC site and didn't see it.
How do I pay? Paypal is easier (for me) if not, happy to bank transfer.
Cheers.
This is going to be interesting!
I cant start the bench yet as I'm still recovering from the bicep tendonitis but I can get into the squat and deadlift program... actually might wait and do all three together so I can judge the progress equally.
So just to confirm, what I'm planning on doing is doing the 3 lifts weekly and throw a 4th day in there somewhere when I can either do general exercises and cardio or possibly alternating between each lift so each lifts gets a turn on getting done twice a week.
On the 3 lift days, I will do the program as per my PB for the individual lift starting with week 1 (is it 60 seconds between sets?) Then I plan on doing 3 other 'assistance' exercises from the list (or some others).
Does that sound OK?
I'm finding that I can bench three times a week, squat twice a week and deadlift once a week... although I've just dialled back the bench to twice a week as I'm getting some rotator cuff pain
I only train 3 x week as I also play basketball
don't aim too high on the starting numbers either... you might be fine week 1 but by 6 or 7 your going to be in trouble
Read the pre-text mate.
It is suggested that you do a movement per day.
eg
Squat monday
Bench Wednesday
Dead friday
follow each lisetd sets/reps with soem assistance stuff (eg front squat after squats)
You can do all 3 lifts on each training day - not many people do.
Some_CS_Student from these forums did it that way and did well.
Most people do it 1 per day
Thanks.
I did read the pre-text and that is how I understood it ie 1 lift per day. Monday - Chest, Wednesday - Squat, Friday - Deadlift. In addition to that I am planning on doing 3 additional assistance exercises that compliment that lift. So 4 exercises in total for that lift.
So how long in between each set of the PPP for the major lifts?
sorry. when you said "on the 3 lift days" I thought you meant the days you do "the 3 lifts" if you get me.. anyway..
Time between sets is as long as it takes for you to recover enough to complete the next set.
it's not cardio
edit.
Not sure about you but I like to keep squats and deads as far apart as possible.
so I'd suggest squats monday, bench wednesday and deads friday.
but up to you.
Edited by TTT
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
