lol I look so tiny compared to those monsters
on a plus note, even though I didn't hit my target total I feel really good today... no niggles, a bit sore but that's it... mustn't be lifting enough weight!
Congratulations Markos, you put on a hell of a show
but I don't have an injured back
yeah was okay off the floor but I think I have to work on the lock out... I got red lights on my 2nd attempt for bent knees... I was wondering why it was taking so long for the down command, I thought I was all locked out... the above was my third lift and I only got two whites so definitely have some work to do
my bench is pretty average... I don't really enjoy it, it's a bit of a bore to train
I've worked really hard at squatting as it's a bit of a weakness so pretty happy with the progress... even though I won't be setting records any time soon;)
what's your PB squat? can you train it okay with your back issues?
Squat PB is 185 without wraps and 190 with wraps....
I've got a long road back for my back I reckon.
Currently doing sets of 8 for squats and 5s for deads.
Doing all deads off my 10kg plates so it's from a deficit.
squats are currently lighter than when I started training for powerlifting.
it's frustrating but not as much as lying on the floor in pain for days, then walking like a cripple for weeks.
yeah I hear ya... back injuries suck as they're almost impossible to train around... like when you get an epic back pump in the gym and you can't even lay on a bench and press!
what's the wisdom regarding doing deads from a deficit... increased ROM for rehab?
Makes them harder.. lol
If I get stronger from a deficit, then regular deadlift will be easier as it will start higher.
I don't have much speed off the floor cause I end up injured when I try to move faster.
So if I get stronger from a deeper position, then it will make me stronger through the whole range.
On the 1RM, what is a good way to test that out? ie after you have stretched, warmed up etc how many sets, what weights should you do before you try and hit the 1RM or doesnt it matter?
I tried bench on Monday but I 'think' I did too many sets first?
60x12
80x10
100x6
110x4
120x1 - this was the 1RM effort - spoilt by a spotter who jumped in at the first sight of struggle, despite being told not to!
Cheers.
so is 110 x 4... I can barely double 110
just make sure your touching bar to chest... the amount of high benching I see is almost equal to the amount of high squatting
bloody bench press... I have to do it multiple times a week for even the tiniest gain... sick of it!
Thanks.
They are definitely touching the chest.... actually maybe the last 2 of the 110 might have been a bee's dick above (didnt have a spotter for that).
The 120kg I even planned to pause at the bottom for a split sec but it was too heavy so lifted as soon as it touched.
Will give it a crack next week with singles above 100kg and see how I go.
Wont mention my squat efforts... :/
Edited by SRS13
    • No, so what happened is. I put a bunch of filler then I sanded it all down, I removed all the filler (unintentionally), then I put the epoxy primer on because that section of the panel is bare metal. The car is parked outside so I needed to protect it in the meantime incase it rains.
    • It’s definitely an import, the Aussie ones have reflectors in the rear bar, it’s also a turbo which none of the Aussie one were.    I remember back in the day I want a twin turbo z32 so bad and then I saw a 32 gtr and that was the end of that lol
    • Same can be said for Subarus motors ha ha!   I like the 300ZX, I nearly bought a Z32 before I bought my first Skyline. It was going to be a project. Then I found out there was a bit of a dodgy title with it... As in, someone attempted to commit insurance fraud with it and there was now some dodgy legalities around it. So at 18 I walked away from it.
    • The below is what the readings I had with the fuel pressure gauge which were correct. It seems like the issue is mainly during drive and not idle. I bought the new hanger hoping it could be the issue, perhaps I ruined something while cleaning, but I have not installed it yet since I have to wire up everything with the new plugs.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
