Powerlifting
markos
 Share
lol
probably at the stage where I need to shave it... get some Markos style... might even get some tatts/piercings! ;)
does stop me from getting hassled driving the R though... the boys in blue must think I'm a bit older and therefore more responsible... ha!
Markos my folks were very impressed with ProRaw4... they only came for a bit, watched the bench press then went home and watched the rest on the live feed
so anyway, day 3 of 'dieting'... verdict: its massively gay
did a lighter, high rep, dumbbell pressing session last night... including lots of shoulder work... low rest times and lots of drop sets... my god is it boring!
hardly raised a sweat so went and did some high rep squats to finish... last set was 100kg x 20... fark
The GPC National Push Pull is on Sunday the 18th. Its run on the same day in each state.
Victoria - PTC Frankston
Queensland - PTC Brisbane
Western Australia - PTC Perth
NSW - PTC Sydney
ACT - Elite Physique
NT - Power Pit gym
I have one SA competitor fly in to compete at Vic
Anyone interested in watching is welcome, entry is free
Thats pretty cool, so no benching at the moment?
Just cleans/snatches/squats/front squats/overheads
Pretty much spot on.
Weightlifting is the only thing I'm really enjoying at the moment so I'll try to capitalise on that while i can.
We have a good gym at work, i'll still bench there and do a few other things, but at least i can really work on the basics
at home.
Once i c&j over 140 i might go back to powerlifting
the start of my new setup at home.
I have 250kg to start with, will have to add to that hopefully.
Very cool setup!
I would love to do some weightlifting but need some coaching first (and somewhere to do it)... I power clean/push press often but never even attempted a proper jerk or snatch... I can't even overhead squat properly as my mobility is poor
170kg bench at > 90kg! ... man I have some work to do :(
sounds good
I've resigned my full time position and am going into business for myself so should be able to get to the PTC during the week next year... Hopefully I can split my training so it's twice a week down there and twice up here
I know much more progress could be made training at PTC
What do the numbers in the gloss table represent?
Glossbrenner is a formula calculator
You punch in your bodyweight, weight lifted and it spits out a score. It also allows for age correction for over 40's and gender
Here is a link on my site, its easy to work with
http://www.ptcfrankston.com/glossbrennercalculator.html
 Share
    • Lots of this, and in older cars, AC is generally controlled by the AC knobs and programming, and the ECU reacts to the load. Modern cars, the ECU controls kicking the AC on/off at the AC systems request so it can be prepared for the engagement/disengagement.
    • Sadly, it won't happen. The AC controls in our cars are essentially on-off. Whereas the AC in new stuff is more a case of variable displacement compressors giving infinitely variable output.
    • I don't think anyone did. But it still made me consider. For me personally it wasn't clear whether the AC experience in my car was shit because it is an old system, or because it wasn't maintained. Looks like it may have just been the latter. I see some more modern setup being sold as an upgrade and I wonder whether it would make it drive like AC in a modern car. Where you don't really hear it or notice it. But maybe that's asking for too much as well.   Haha, stick it in a Nissan Cube and you end up with a driveable fridge I'm not doubting your experience. Just thought it was interesting to hear the AC technician's thoughts on it.
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
