see how bad the damage is from the scan. Determine If surgery is needed or not.
2-3 physio sessions a week to start with, stretches once 'healed' and then back into movements like running.
Start back into squats etc. once I get the ok. See how it goes
Depressing really, I feel I was makin good progress
Edited by jangles
Thats his heavy stuff done till States. He should total 650kg. This time last year I was lying in ICU so Max couldnt compete as he ran the show, he was at around 550kg. Before Nats he got injured, he was aiming for 600kg. At Worlds he got 650kg.
This year he is starting 100kg up. He plans to total around 725kg this year. The Junior WR is 690kgin the 90kg class.
At Worlds he weighed 86kg in the 90kg class, didnt have to make weight, in fact he's never had to make weight, lifting too light. 3 days before weigh in he was 84kg, he could easily have lifted in the 82.5kg, but he doesnt change plans midstream. He is currently 89.2kg in the morning.
By Nats he will have to make a decision as I reckon he might be 93-95kg, cut or lift in the hundreds, he's not fond of cutting, but he has definite plans and goals
he's very patient and focused... I'd back him to be over 700kg this year for sure
I trained yesterday at PCYC and had absolutely nothing... probably pushed myself a bit too hard, the stuffy nose and high temp came back last night... stupid cold has completely zapped me... still plenty of time to fully recover before states though... hopefully I can do some more quality heavy stuff this week, I'd like at least another sessions practice in the knee wraps
no excuses, I'll be ready come comp time and nothing bar a freak natural disaster is stopping me from a 200+kg squat
then 600+ at Nats..................
He weighed 77kg at the ProRawQualifier, benched 150kg
Today he weighed 83kg, benched 157.5kg
A few weeks ago he benched 80kg x 24, bodyweight
He actually filmed it for this website, I told him I wouldnt post it up, so he deleted it
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
