The reality is though, I'm not a competing lifter so the pause isn't a big thing. As long as I'm not bouncing the bar off my chest, just lowering and pressing in a controlled manner that's all that I care about.
I agree however pausing reps may assist with shoulder health... from what I've read
have you had a go at the Bamboo bar Markos has there?
had a quick muck around with it but that's about it... very odd to use... I imagine its similar to doing push ups on rings / TRX straps... building the stabilisers in your shoulders by pressing an instable object
I'm still trying to press a stable object correctly lol
nope from what I understand, Bench press is a test of shoulder health. You do need stronger shoulders/ scapular support to do it though, it's definately harder than not pausing.
Just curious as to whether any of you do rack pulls to improve your deadlifts?
Asking because my deadlifts are up at around 145kg, whereas my rack pulls are around 180-185kg.
It would seem the lower section of the lift is what I need to work on (my lock out is strong)
Any good ways to go about this?
I would have thought everyone would be stronger on rack pulls than deads, given it's only half the movement.
Deadlifts on a deficit, power cleans, should help with lower back.
Rows are upper back, but they do strengthen core and lower back at the same time. Seated row with lower back movement might be good.
Yeah I know it's always going to be the weaker part, this is why I want to work on it.
Once I improve that drive off the floor I'll be pulling some respectable numbers.
My gym doesn't have kettlebells so I'll give deficit deads a shot.
In my limited experience and understanding the floor part is sometimes mucked up by a combination of things. I am trying to remember it was a long time ago.
Most often I reckon getting the bar off the ground issues are 'the setup' and things like the approach based on your flexibillity and body mechanics.
When I started doing some deads again for that challenge, I had to start stretching my ankles to ensure I had enough dorsiflexion. I had bugger all straight away,to what is really needed. I still need to work on it if I ever want to play with something heavy.
Try these if you haven't already.
* Take all slack out of the bar hold before going for it. Stretch into tension by griping the bar and pulling up to point of tension a couple of times before the real lift. Crush the crap out of the bar. If there is any slack at all in the grip, then energy is lost as it's taken up (and the hips are probably going to leave the bar behind)
* Hips trying to come up too early as you try to 'heave' the bar off the ground.
* You need to 'push' yourself away from the floor and drive through the feet. (This is probably one of the most effective tips for getting the bar off the ground).
* Drive hips through the bar.
* Keep the tension in the back/lats not just the abbs.
I reckon posting a vid and someone like Markos can give you some pointers.
One thing I slacken on from time to time...but it makes a big difference...is starting with that bar pressed right up against your shins. The closer to your centre of gravity, the easier it's going to be to get that sucker off the floor. This means dragging the bar up your legs (grazing them on knurling haha) as you lean back and drive hard with the heels.
Every now and then I find the bar a couple of inches in front and I have to slap myself for it.
Mark ripptoe explains it well in starting strength.
Scapula should be directly over top of the bar, arms vertical, bar in the middle of your foot (which will usually find it resting against your shin/ankle). Pretty much what I recall his deadlift guide explaining.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
