Powerlifting
markos
 Share
The most I got to on SLDL was 120x10 before switching to off the ground. They were certainly tough, particularly on grip because you can't rep reset like off the ground. Great for people with limited flexibility too.
Do you guys do any grip specific training or just let the compound pulls do their work over time? Is there such an exercise as just standing there in a lockout until your grip starts to give way?
What an odd sponsorship...does it net much in the way of sponsor return for Emad or is it more because he loves the sport?
Loves the sport more than anyone I know, and has done more in 18 months than most have in 18 years for powerlifting.
The whole story will never be revealed though
Didn't do the week 11 of the PPP 180kg deadlift but did the following;
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
Got my 180kg PB! It was nice seeing 4 x 20kg plates each side lol. Am absolutely wrapped with that.
Weighed in today at 78.9kg so lightest I have been in 15 years yet have lifted more than I ever have.
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
it's a good reward when you see the numbers go up
60 x 5
100 x 5
140 x 5
150 x 3
160 x 3
170 x 1
180 x 1
Grats dude! :)
192.5/100/210 - 502.5 at 87.9kg
2.5kg PB / 10kg worse than PB / 10kg worse than PB.
5kg lighter bodyweight.
Happpy with the sq PB.
The others are still weak but it's as good as I could get them since last injuries.
Hoping to improve SQ and deads by June.
Bench will prob stay the same cause I won't be training it much if at all.
Once again, I hate wraps.
so so much pain.
Edited by TTT
Back held up good.
just not as strong.
Hopefully improve by Nats to better my own PB.
My wife goes "hey you got a weird tan line at the back of your leg with that soft suit" last night.
I go come have a closer look.
She freaked out at the bruising.
I'll take a pic.
 Share
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
    • It could be. It might not be. It is impossible to know without context by asking the owner or the tuner on the day and knowing what they were doing/not doing/attempting to do. You said earlier this is hard to understand because to your mind, a turbo is at full speed when it hits its spike. This is not true. The turbos actual speed is defined by how much air is being forced through it via the exhaust, unless you control it. The spike you are seeing at ~whatever RPM it 'spools' at, is where boost control is starting. If there were no boost control the turbo absolutely would be spinning much faster at 7000rpm than 3000rpm, every single time, on every single engine. Boost control keeps the boost controlled within the limits you ideally want. If it were uncontrolled you would have two scenarios 1) You have a turbo that hits peak RPM and CFM (not boost) at the redline of the engine. This would work, but most people want more boost earlier. 2) You have a turbo that hits peak RPM well before the redline of the engine (say, 3500), and you explode the turbo by redlining the engine. (say, 7000rpm). If you don't want exploding things, or lag, you design a turbo system to come on when you want the boost to be useful, and then not overspin itself into oblivion by using some form of boost control, to control the boost pressure accordingly.
    • Yep. >10 posts required. Prank can relax that for individuals when required.
    • @PranK is there a restriction on posting pics based on post count?
