well i went to PTC Sydney yesterday and had an evaluation with Trent. I must say, top bloke, very knowledgeable, not judgmental and explains everything to you in detail.
He sorted a couple of issues that my younger brother was having out in about 30 seconds (particularly squatting) and in the session, young 17 year old 90kg Jack went from struggling to squat 70kg below the parallel to squatting 100kg almost ATG. My squat however went backwards, I got lower almost to ATG but only managed 70kg in the squat rack before form started to drop.
Also tweaked our bench to more of a strong man bench. I can speak now from experience a PVC pipe under your back whilst trying to bench sucks balls (I have the bruises to prove that), seems to have helped Jacks bench technique as well.
Finally we did some Deads, probably my new favorite exercise. Got to 100kg x 3 reps before form started to break. This was after he changed the entire way that I dead.
Trent has also recommended that we add in some leg press and lower back raises to help us with these main lifts and thinks we should go back in about 6 months for another quick session. If the gym wasn't so far away and I wasnt as busy as I am with work, uni, other sporting commitments and the girlfriend I would sign up in an instant. Really enjoyed the entire environment that I witnessed at the gym with all the guys there.
If TL:DR here is the summary, good session, good gym ended up lifting more and less. Would recommend anyone to have a session if they are unsure and will go back.
Thanks guys, its great when the hard work pays off.
Very interesting. I should book a visit when my shoulder is better.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
