I started this thread because there was so much stuff being posted that I didnt agree with in other threads, but I realize that not everyone wants to be strong
This thread is for those that do
So my posts in my powerlifting thread will always be about increasing your 1RM
Looks like I'm going to be getting lots of bench practice for the next week or two
did something to my lower back... right down the bottom, near my upper glutes... can't bend over at all... sitting and standing are very painful... lying down is okay... getting dressed is a challenge... might just go to bed clothed, will make things easier tomorrow lol
I've strained my erectors before but this is different... lower down and much more painful
I'm lifting at Nats... even if I have to do so in a wheelchair... so my back can kiss my arse
there's two vaginas... a front one and a back one;)
yep will be seeing Jason Mawby as soon as i get the correct phone number lol
leg movements are okay... walking not too bad... hurts to twist
anything remotely like a deadlift movement hurts the worst... TBH I'm pretty sure I did it last week... thought it was just tightness/soreness so I did a long warm up and lots of rolling... felt sore but I went for my working set anyway... it didn't pop or anything just knew as soon as I'd finished the set I was in trouble
just hit it with the hot water bottle and it's a bit better... which leads me to think it's just a strain... hopefully I can just skip squats/deads this week and it comes good
Wayne slipped on a roof and cut his leg very badly... Liam has a knee issue that he had surgery for... surgery didn't work but then they found another issue that needs time to heal
I think I hurt my back as a direct result of giving Wayne crap about having to load his plates for him... karma is a bitch
I'm off to see Jason tomorrow morning, then drop in at PTC for a bench session after... hopefully it's just an alignment issue, maybe a pinched nerve that can be fixed with some manipulation
That time of the year again. A few of my guys are riding that fine red line atm as they prep the final stages for nats.
Seeing emads snap has shocked a few of the guys into spending more time on
Mobility - rehab and prehab is up more than normal.
Edited by trentzor
Saw Jason this morning, have to go back on Thu after I get my X rays
he told me to stand in front of the mirror and showed me how crooked I am... it was ridiculous and weird that I've never noticed it before
he did say it's possible I have bulging or slipped disk but I think I'd be in much more pain... definitely no nerve damage which is good... lots of ice for the next 48hrs
hopefully the ice will reduce the inflammation, the x rays will be clear and some manipulation will have me back lifting in a week or two
he did say once he gets me straightened out I should see a strength increase
on a brighter note I benched 125kg x 3 for 3 sets... still on track for my first 3 plate bench press
lol......no amount of prehab would save anyone from what happened to Emad
The operation is tonight, they are doing a biopsy on his bone to find the cause of the snap, as in disease, it has nothing to do with lifting weights, your humerus doesnt snap benching 110kg. It doesnt snap benching 400kg. It snaps if there is an issue with the bone.
I know mate lol. I should have clarified.
His was a freak accident.
Nothing could have prevented it.
It's pretty rare though I haven't seen such a break before.
Any specialist ideas on what caused it?
Plenty of guys bench for years without snapping it as such.
Keep us updated on how his going after op.
Edited by trentzor
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
