I started this thread because there was so much stuff being posted that I didnt agree with in other threads, but I realize that not everyone wants to be strong
This thread is for those that do
So my posts in my powerlifting thread will always be about increasing your 1RM
Looks like I'm going to be getting lots of bench practice for the next week or two
did something to my lower back... right down the bottom, near my upper glutes... can't bend over at all... sitting and standing are very painful... lying down is okay... getting dressed is a challenge... might just go to bed clothed, will make things easier tomorrow lol
I've strained my erectors before but this is different... lower down and much more painful
I'm lifting at Nats... even if I have to do so in a wheelchair... so my back can kiss my arse
there's two vaginas... a front one and a back one;)
yep will be seeing Jason Mawby as soon as i get the correct phone number lol
leg movements are okay... walking not too bad... hurts to twist
anything remotely like a deadlift movement hurts the worst... TBH I'm pretty sure I did it last week... thought it was just tightness/soreness so I did a long warm up and lots of rolling... felt sore but I went for my working set anyway... it didn't pop or anything just knew as soon as I'd finished the set I was in trouble
just hit it with the hot water bottle and it's a bit better... which leads me to think it's just a strain... hopefully I can just skip squats/deads this week and it comes good
Wayne slipped on a roof and cut his leg very badly... Liam has a knee issue that he had surgery for... surgery didn't work but then they found another issue that needs time to heal
I think I hurt my back as a direct result of giving Wayne crap about having to load his plates for him... karma is a bitch
I'm off to see Jason tomorrow morning, then drop in at PTC for a bench session after... hopefully it's just an alignment issue, maybe a pinched nerve that can be fixed with some manipulation
That time of the year again. A few of my guys are riding that fine red line atm as they prep the final stages for nats.
Seeing emads snap has shocked a few of the guys into spending more time on
Mobility - rehab and prehab is up more than normal.
Edited by trentzor
Saw Jason this morning, have to go back on Thu after I get my X rays
he told me to stand in front of the mirror and showed me how crooked I am... it was ridiculous and weird that I've never noticed it before
he did say it's possible I have bulging or slipped disk but I think I'd be in much more pain... definitely no nerve damage which is good... lots of ice for the next 48hrs
hopefully the ice will reduce the inflammation, the x rays will be clear and some manipulation will have me back lifting in a week or two
he did say once he gets me straightened out I should see a strength increase
on a brighter note I benched 125kg x 3 for 3 sets... still on track for my first 3 plate bench press
lol......no amount of prehab would save anyone from what happened to Emad
The operation is tonight, they are doing a biopsy on his bone to find the cause of the snap, as in disease, it has nothing to do with lifting weights, your humerus doesnt snap benching 110kg. It doesnt snap benching 400kg. It snaps if there is an issue with the bone.
I know mate lol. I should have clarified.
His was a freak accident.
Nothing could have prevented it.
It's pretty rare though I haven't seen such a break before.
Any specialist ideas on what caused it?
Plenty of guys bench for years without snapping it as such.
Keep us updated on how his going after op.
Edited by trentzor
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
