Its full already. We have 4 custom deadlift platforms being made for the powerlifting area, then the 3 platforms already in there move out to the only vacant spot in the gym.
In the PL area we have
4 monolifts
4 Forza bench presses
4 deadlift platforms
Westside Reverse Hyper
1700kg calibrated plates
4 wrap rollers
3 chalk bins
bands,chains,specialty bars,boxes
Rest of the gym
6 power racks
3 squat/bench combo racks
3 deadlift platforms
1 weightlifting platform
1 Westside Reverse Hyper
1 GHR
7kg - 65kg dumbbells
4kg - 80kg kettlebells
dip bars
many chin bars
7 flat benches
2 incline benches
We also have an area for rehab. We've managed to get a few first and second generation Nautilus machines from the mid to late 70's. These were designed by Arthur Jones and are the finest machines ever made. They have chains, cams and gears, no pulley and cable. They include
Nautilus Double Shoulder
Nautilus Pullover
Nautiles Multi Bicep
Nautilus Row
Nautilus Pulldown
Nautilus Pulldown behind neck
Nautilus Leg Extension
Nautilus 70 degree shoulder
Nautilus 4 way Neck
We also have a Hammer Strength Uni Lateral leg press
A ton of bars, specialty bars, 2000kg of bumper plates, Strongman implements
Plenty of stuff I've left out, so as you can see it fills up quickly
Edited by markos
  • 3 weeks later...
From what I've heard and seen, atmosphere appears to be very similar amongst all the PTC gyms.
There are a tonne of lifters ACTUALLY competing this weekend out of PTC Gyms all over. Around 90 lifters from PTC's, Melbourne, Brisbane, Sydney, Perth and Gold Coast
I think one of the reasons the franchise has worked so well is that the clients all progress quickly due to everyone having a goal. We have picked up 30 clients in the last month since moving.
We had a 17yo come for a look recently, trained elsewhere. He watched Conor squatting 240kg, I mentioned they were the same age, he was blown away.
Same thing happens when girls come in, thinking that heavy weights makes them huge, they then see Vicki, Sussy, Nina, Rebecca or Heidi out deadlifting most men and all weighing around 60kg
Its an eye opener when you first walk into a PTC
  • 3 weeks later...
Had my Novice Comp on the weekend, 11 lifters, only one had competed before, a Novice Comp 12 months ago, Joe Pavone
Daniel Kranitz - 17 - 76.6kg - 105/75/150 - 330kg
Jason Wu - 19 - 73.5kg - 105/90/165 - 360kg
Brett Daly - 21 - 58.9kg - 135/100/130 - 385kg
Martin Patience - 48 - 74.9kg - 140/100/160 - 400kg
Justin Bigornia - 21 - 65.9kg - 130/92.5/177.5- 400kg
Rico Adhitya - 20 - 70.8kg - 142.5/107.5/170 - 420kg
Joe Pavone - 29 - 81.4kg - 140/105/185 - 430kg
Arthur Krasicki - 25 - 95.1kg - 155/100/200 - 455kg
Jason Chieng - 27 - 75kg - 185/130/215 - 525kg
Simon Light - 36 - 134.8kg - 185/115/245 - 545kg
Alex Deken - 21 - 89.1kg - 210/160/230 - 600kg
Read more: http://www.prorawpowerlifting.proboards.com/thread/1861/ptc-july-novice-comp#ixzz2Z57tJNFU
Interesting thing about Joey, big talker, trained at PTC for 3-4 sessions, a few of his mates lifter here, bought a crowd to watch him. A year after his first comp he comes back to see how much he's improved. Nothing, zero. Trains at FF South Yarra.
I pointed out to him Alex beat him by 170kg and Jason is lighter yet still beat him by 95kg, both boys have been here about 7-8 weeks.
Now wants us to do a program for him...........its not the program girlfriend.
Thing is at FF he is "strong", he didnt like it here, guys in his class total 250kg more than him, pretty embarrassing, IF you have an ego.
The guy is straight on FB this morning telling all his clueless friends how well he did.
Guys like this dont train at PTC nor do they ever improve.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
