Powerlifting
markos
 Share
Haven't tried these but I'd be interested in giving it a go. Used to do superman push-ups fairly easily so these shouldn't be comparatively as hard?
Boz have you tried captains chair leg raises as opposed to hanging?
You can try on my ab wheel ;)
I can squat 200kg+ and my abs were sore for days after using it all the way to the floor from the knees lol.
Yeah I was doing the captains chair leg raises, but current assistance template has the ab wheel in there specifically, as well as the PL gym not having a captain's chair!
  • Like 1
Had a decent day at the recent GPC comp in Melbourne. Went 6 for 6 on squats and deads but botched my bench press... again... only getting my opener, which was 10kg down on my gym pb (150kg) I set a week before the comp
I ended up with 255/140/265 for 660kg @ 96.5kg and first place in the 100's. Actually totalled the same as the guy in 2nd but weighed 2kg less so I get the win.
Only a small comp, most of the strong guys did ProRaw and sat this one out, but still nice to place for once!
Squat and dead weren't max efforts so looking for a 700kg total next year
  • Like 2
Cool mate, well done on first, that's a sensational win. I can remember you only dreaming of figures like that!
When is PTCs next push/pull or novice comp?
My figures are coming up so I would not mind attending the next novice and beating previous total.
Push pull is on the 7th of December and there's a novice on the 21st.
I was going to do the push pull but have a wedding on that weekend.
I'll be at the novice though.
Thanks mate, progress has been pretty consistent apart from time out due to injury. Still a long way to go before I'm truly competitive.
Farking hate Facebook
Can someone down with social networking post details here
Can you just show up on the day and sign up then?
Push/pull 24hr weigh in on Saturday 11-3pm, must be a gpc member prior to event. Lifting starts 11am Sunday 7th. $50
Novice is 21st, $30, 11am start. Same day weigh in
  • Like 1
Just join facebook and add shit you want to hear from.
all the selfie faggotry have moved instagram.
I only joined this year.
and only so I'm in the loop of goings ons as forums are on the decline.
  • Like 1
  • 3 weeks later...
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
