On the 1RM, what is a good way to test that out? ie after you have stretched, warmed up etc how many sets, what weights should you do before you try and hit the 1RM or doesnt it matter?
I tried bench on Monday but I 'think' I did too many sets first?
60x12
80x10
100x6
110x4
120x1 - this was the 1RM effort - spoilt by a spotter who jumped in at the first sight of struggle, despite being told not to!
Cheers.
Been a while but finally managed to work out some 1RM's;
120kg bench
165kg deadlift
110kg squat (no comments lol)
Decided my starting weights on the PPP are going to be;
130kg bench
180kg deadlift
120kg squat
I figured that if I go through the program and it becomes too much on a certain week I will drop to the lower weight program for that week and do the weights stated there. I didnt want to start too low and not gain much overall improvement on the PB.
So started the deadlift PPP yesterday and was OK. Lower back feels it today. Today off and tomorrow chest.
Squat and deadlift are great. Bench is a bit low compared to them, any reason? What do you weigh again?
A competition bench is done with a pause on the chest, bum on the bench, feet cant move
Many that have lifted at my novice comps are stunned how much they lose when they have to it properly
That will be a great total Nick at sub 90kg, 565kg at your first States is great. Max did 462.5kg at his
Very different to a gym lift
Although it's sometimes a downer first time you try, once you learn how to do it properly it eventualy helps you lift more. Most people don't drive through their feet etc.
Edited by rev210
Oh, I agree. Max's PB is 155kg paused, he's never tried more touch and go. In fact he pauses all his reps now
Gym lifters drop over 10kg when they try to pause, some drop another 10 when they have to touch there chest
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
