I find I can squat and bench multiple times a week and still get quality work in on other movements
but deadlifting has to be planned out a bit because of the lower back fatigue... once the lower back and grip is gone I find it hard to do much else and need a full 48 hours to recover... otherwise my workout is compromised... lots of foam rolling on the lower back helps
I used to give equal time to squatting and deadlifting but now I'm focussing more on squatting and just deadlifting once a week... I find a stronger squat helps the DL, but it doesn't work the other way round
Catherine Pascoe - 59.8kg - na/55/90 - na
Troy Hewlit - 87.4kg - 110/77.5/152.5 - 340kg
Kris Baldry - 97.2kg - 170/90/190 - 450kg
Armando Miotti - 90.7kg - 172.5/110/180 - 462.5kg
Hoan Dang - 89.5kg - 162.5/125/215 - 502.5kg
Stelian Tchapkanski - 95kg - 150/145/210 - 505kg
First time for a while where we had only novices, no lifter was a member of a fed
No novice comps in February or March due to the ProRawQualifier and Vic States
April before our next novice comp
Edited by markos
^^ you don't have runners?
I've got a $20 pair of K-mart specials lol - I don't ever really use them. The closest I get to an activity that warrants runners would be riding my bike, which I wear my skate shoes :P
I do actually have a pair of Vans Authentics that I've squatted in before and they did quite well, though personally I prefer barefoot anyway.
i'm not talking about just lifting, I wear weightlifting shoes for most most of my lifting.
I didn't realise he didn't run, sprint, do circuits, play some sport, or do anything apart from lifting weights.
I sprint barefoot on a grass track :P I ride a downhill bike which is horrifically inefficient when not going down a hill....aaaaaaand I'm considering taking up soccer again this year, so I'll obviously need to buy boots for that. If I have time for it at least.
I just don't have time and couldn't be f**ked doing anything other than the above on top of lifting. Don't see the point.
I don't do any of those.
Drive to work in Business attire.
once home I walk the dogs
then lift
then repeat.
I do have sneakers though... for the walking of said dogs
Edited by TTT
^ I used to think the same, now I look over to my shoe rack and see work boots, black business shoes, and trendy fasion shoes not suitable for anything practical. Oh how the times change, back in the day all I used to have was runners, would wear them everywhere.
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
