yep it starts gently but gets painful quickly
if training for strength you want to be fully recovered for each of your heaviest sets... it can be 5 min or longer... you want to approach the set with 100% effort and focus... it's a bit of a balance between recovering fully and getting cold (which isn't much of an issue at the moment)
cheers
last week was easy, I felt like I could go much heaver... this week was just 5kg more but was super tough... I have burst a blood vessel in my eye, look like a stoner lol... need more practice in the wraps
I also did 115kg x 3 on the bench press yesterday which is a PR... not very impressive I know but I'm making progress which is nice
poor Martin
Righto, I'll try out 3 mins or so and see how I go.
I tested out my 1rm for bench yesterday without a spotter (but in my cage with safety's) and I got 105kg.
So should I do the 115kg program or 120kg?
Which one do you think is achievable in 3 months? I played it safe and only went 10kg up on bench. if I gain 40kg on bench in 12 months, I'll be exstatic.
I did 120kg 1RM on the bench and tried the 140kg PPP, by week 4 it was too much. I was giving myself 3 minutes between sets which probably wasn;t enough but even then the weight would have been a struggle.
I think 10kg is safe, 15kg is hard and 20kg is really pushing it, if not too much.
Thats right, try it and see as everyone is different.
I mentioned on my ProRawForum how Zoran started on the 180kg deadlift program first week of September. He told me it was his old PB, he pulled a very hard 160kg in front of me, so we started on 180kg.
Before I got back from Worlds late September, his assistance exercises included 220kg pulls from a deficit for reps. In late November he deadlifted 280kg at the National Deadlift comp, on the weekend he pulled 290kg
This guy doesnt even drink protein shakes, has a 130kg improve in 5 months, he may be 2-3kg heavier
my mate swears by that craze stuff... but he gets out lifted by girls so I never bothered with it
I'm glued to the couch watching basketball today... just those couple of tough grind squats yesterday have broken me
might just lay down on that comfy new bench tomorrow
This just makes me think what the hell was he doing before!
So many gains
if only... Sigh.....
I'm trying + 20/10/20
Edited by jangles
Who would have it any other way! All star weekend this weekend as well.
I agree that 15kg is a pretty optimistic jump for 11weeks on any exercise, but hopefully i can get it done. Is it a good idea to change up the reps of the assistance exercises each week ie 5 reps one week and then 12 another week and 8 the next etc or should i stick with one?
Zoran came from a boxing back ground
Made a decision to compete in powerlifting and joined our gym
Started at 140/120/160
Now 235/145/290
He is 23 and been training in gyms like others do, his lifts were okay in a regular gym
I hear Craze is off the market now
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
