had a very successful States... I went 9 for 9, setting a PB on every lift
squat 210kg
bench 132.5kg
deadlift 240kg
unfortunately the 90kg division was very strong so I came 4th... if I had of lifted in any other division I would've got a medal
was an amazing job Markos, how you and the crew managed to run a meet with so many lifters and spectators out of that little gym was super impressive
bring on Nationals:)
Cheers! I had a good day... I like comps, I find I can get a few extra kilos just due to the atmosphere
I started doing PPP 3 times a week after my first novice comp which was last year in September I think... that was at my old gym with the odd weekend session at PTC... since mid Jan this year I've been training 4-5 times a week, mainly at PTC, doing a mixture of PPP and whatever Max tells me to do
booked in to have a coaching session with Trent from PTC Sydney next Saturday. Will be interested to see if I have been dead lifting or squating incorrectly.
also any other tips that he can give.
I think it will be more beneficial for my brother who has only just started going to the gym.
Nick, some are destined to stay weak and small, they'll never understand you eat for size and lift for strength, as you pointed out, Martin and Gregg are both Elite, different builds. Same training, one eats more. It doesnt seem difficult to understand. Anyway, please dont post that crap in here, its clearly a PL thread, PL is a sport.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
