The reality is though, I'm not a competing lifter so the pause isn't a big thing. As long as I'm not bouncing the bar off my chest, just lowering and pressing in a controlled manner that's all that I care about.
I agree however pausing reps may assist with shoulder health... from what I've read
have you had a go at the Bamboo bar Markos has there?
had a quick muck around with it but that's about it... very odd to use... I imagine its similar to doing push ups on rings / TRX straps... building the stabilisers in your shoulders by pressing an instable object
I'm still trying to press a stable object correctly lol
nope from what I understand, Bench press is a test of shoulder health. You do need stronger shoulders/ scapular support to do it though, it's definately harder than not pausing.
Just curious as to whether any of you do rack pulls to improve your deadlifts?
Asking because my deadlifts are up at around 145kg, whereas my rack pulls are around 180-185kg.
It would seem the lower section of the lift is what I need to work on (my lock out is strong)
Any good ways to go about this?
I would have thought everyone would be stronger on rack pulls than deads, given it's only half the movement.
Deadlifts on a deficit, power cleans, should help with lower back.
Rows are upper back, but they do strengthen core and lower back at the same time. Seated row with lower back movement might be good.
Yeah I know it's always going to be the weaker part, this is why I want to work on it.
Once I improve that drive off the floor I'll be pulling some respectable numbers.
My gym doesn't have kettlebells so I'll give deficit deads a shot.
In my limited experience and understanding the floor part is sometimes mucked up by a combination of things. I am trying to remember it was a long time ago.
Most often I reckon getting the bar off the ground issues are 'the setup' and things like the approach based on your flexibillity and body mechanics.
When I started doing some deads again for that challenge, I had to start stretching my ankles to ensure I had enough dorsiflexion. I had bugger all straight away,to what is really needed. I still need to work on it if I ever want to play with something heavy.
Try these if you haven't already.
* Take all slack out of the bar hold before going for it. Stretch into tension by griping the bar and pulling up to point of tension a couple of times before the real lift. Crush the crap out of the bar. If there is any slack at all in the grip, then energy is lost as it's taken up (and the hips are probably going to leave the bar behind)
* Hips trying to come up too early as you try to 'heave' the bar off the ground.
* You need to 'push' yourself away from the floor and drive through the feet. (This is probably one of the most effective tips for getting the bar off the ground).
* Drive hips through the bar.
* Keep the tension in the back/lats not just the abbs.
I reckon posting a vid and someone like Markos can give you some pointers.
One thing I slacken on from time to time...but it makes a big difference...is starting with that bar pressed right up against your shins. The closer to your centre of gravity, the easier it's going to be to get that sucker off the floor. This means dragging the bar up your legs (grazing them on knurling haha) as you lean back and drive hard with the heels.
Every now and then I find the bar a couple of inches in front and I have to slap myself for it.
Mark ripptoe explains it well in starting strength.
Scapula should be directly over top of the bar, arms vertical, bar in the middle of your foot (which will usually find it resting against your shin/ankle). Pretty much what I recall his deadlift guide explaining.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
