I would have loved a coach when I first started.
Even if just to show me how to do the lifts correctly. For a long time I couldn't squat with an olympic bar because of the pain my lower back received Even now with dead lifts there is a slight bow when i bottom out.
I am going to see Trent at PTC Sydney for this coaching to help get it right.
Also find with a good coach (speaking from other sporting activities) I stay motivated for longer and try harder. Wayne Bennett says he doesnt teach his professional players anything new, he just manages them personally.
food for thought.
Sorry I havent been on for so long, very busy, went to Canberra for the States up there, anyway
Rack pulls. We dont do them as they teach bad habits (hitching). We place the plates on blocks so it mimics the way a bar leaves the floor. We have numerous heights.
Half our lifters pull more off a block, the other half less. Not having momentum at a sticking point makes it much harder. Max has pulled 310kg when he was 75kg, he doesnt get much out of them. Zoran pulls 292.5kg off the floor and 270kg off blocks, clearly he needs the "run up" off the floor.
The best exercise for sticking points I feel is pause deads at your sticking point, stop for a count of 2, then finish the rep.
We love deficit reads, not sure it helps off the floor though as you can use more leg drive on a deficit that isnt there off the floor, but its a great exercise regardless. Do them
5x5 and those clowns claiming it and followers who have no idea why it exists
Bill Starr came up with 5 x 5 when he was asked to write a program for high schools in America to use. Initially he wanted squat/dead/incline but most schools didnt have an incline so he switched to bench press. The 5 x 5 is funny. He said the PE teachers using it were not very smart, and would struggle with a different rep/set scheme, he knew that anyone could remember 5 x 5 lol, so all you guys following it thinking your on something special, think again.
The fact is there is no "best" program, but youre doing one cause its easy to remember and some clown put his name to a program Bill wrote out for dumb PE teachers.
The effort is the key.
To those that claim paused benches are only a benefit for comp lifters, lose the ego, no different to full squats and not hitching your deeds, do the movement properly, your joints will thank you for it when you move to "man" weights
Coaches are important for those that have aspirations, a regular guy at a commercial gym does not need one, he doesnt care that mums can rep his squat PB, nor should he, its clearly not why he lifts, its a social outing, so he can tell his mates he lifts etc.
I hope I havent missed anything. Like I said I was in the ACT over the weekend, awesome comp, some great lifting
I'll post some vids
Big mistake, got injured, ruined his comp. Nathan was planning on 415kg squat, 225kg bench and 330kg dead, a 970kg total to break the All Time 110kg equipped record of 965kg
At the top of the squat he hurt his clavicle and rib, didnt take another attempt, took 2 token benches etc, ended up with 910kg
Jack Hobson benched 180kg at 19yo.....very strong kid
I just realised I have no vids from the Vics up
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
