well i went to PTC Sydney yesterday and had an evaluation with Trent. I must say, top bloke, very knowledgeable, not judgmental and explains everything to you in detail.
He sorted a couple of issues that my younger brother was having out in about 30 seconds (particularly squatting) and in the session, young 17 year old 90kg Jack went from struggling to squat 70kg below the parallel to squatting 100kg almost ATG. My squat however went backwards, I got lower almost to ATG but only managed 70kg in the squat rack before form started to drop.
Also tweaked our bench to more of a strong man bench. I can speak now from experience a PVC pipe under your back whilst trying to bench sucks balls (I have the bruises to prove that), seems to have helped Jacks bench technique as well.
Finally we did some Deads, probably my new favorite exercise. Got to 100kg x 3 reps before form started to break. This was after he changed the entire way that I dead.
Trent has also recommended that we add in some leg press and lower back raises to help us with these main lifts and thinks we should go back in about 6 months for another quick session. If the gym wasn't so far away and I wasnt as busy as I am with work, uni, other sporting commitments and the girlfriend I would sign up in an instant. Really enjoyed the entire environment that I witnessed at the gym with all the guys there.
If TL:DR here is the summary, good session, good gym ended up lifting more and less. Would recommend anyone to have a session if they are unsure and will go back.
Thanks guys, its great when the hard work pays off.
Very interesting. I should book a visit when my shoulder is better.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
