what was the point of that vid?
some chick lifts 235 lbs (105kg) then drops it.
a 26 year old 44.8kg girl deadlifted 135kg on the weekend.
and lowered it too.
didn't scream.
Its crossfit. Very angry individuals.
LOL TTT... you get me every time
my Mrs accidentally tried to deadlift 95kg last night... apparently she mis-loaded the bar... broke the ground with 3 attempts but couldn't lock it out... then got really angry thinking it was only 75kg... when I heard the story I had a good chuckle
silly woman
Edited by NickR33
This is Max playing around in a bench shirt for the first time. For those that dont know, powerlifting has two divisions, raw, which is what 99.9% of regular gyn goers do, and equipped.
With equipped, the lifter wears "suits" or "shirts" to allow them to lift more weight. Its actually a different sport to raw, you actually miss lifts because the weight is too light, like in this video. Max can bench 160kg at the moment, but 140kg wasnt heavy enough to touch his chest.
I am slowly going to introduce equipped lifting on here. I dont expect you guys to adopt it, but I'll try and get you guys to understand it.
An equipped lifter is not compared to a raw lifter.
Australias best powerlifter is Wayne Howlett. He has the All time biggest totals in raw and equipped.
Raw its 935kg and equipped its 1010kg
Anyway, here is the vid
and lowered it too.
didn't scream.
I thought the lowering phase wasn't encouraged on heavy lifts. Heard that from strong-man Elliot Hulse
Strong-man is not powerlifting.
Deadlifting a barbell is not a strong-man event..
A deadlift is lifting a stationary weight off the floor and lowering it back down.
not lifting it off the floor then releasing it.
Deadlift in powerlifting requires you to lower it in a controlled manner. this doesn't mean slowly, but it does mean controlled and not dropped.
dropping it from the top means the lift is not counted.
Dropping it from the top at any gym will mean you're kicked out.
anyway, congrats to the super strong girl who deadlifted 105kg then threw it and screamed which is a good effort because she doesn't spend 6 days training for strength which was stated on the video in invisible html code obviously.
Wonder what she is lifting now it's 4.5yrs later in 2013
Isnt it an NA auto 4 cylinder?
The merc? Or cefiro?
The merc is a turbo 4 cylinder.
Ive put in a turbo back exhaust and remapped it recently. Not sure how much more im getying out of it atm.
/shrug
Specs
Puahing Number of cylinders 4
Engine size 1.8 L
Fuel PULP
Engine aspiration Turbo charged
Driving wheels Rear
Claimed max power (kW) 135 kW @ 5250 rpm
Claimed max torque (Nm) 270 Nm @ 1800 rpm
Transmission 7-speed automatic
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
