Its full already. We have 4 custom deadlift platforms being made for the powerlifting area, then the 3 platforms already in there move out to the only vacant spot in the gym.
In the PL area we have
4 monolifts
4 Forza bench presses
4 deadlift platforms
Westside Reverse Hyper
1700kg calibrated plates
4 wrap rollers
3 chalk bins
bands,chains,specialty bars,boxes
Rest of the gym
6 power racks
3 squat/bench combo racks
3 deadlift platforms
1 weightlifting platform
1 Westside Reverse Hyper
1 GHR
7kg - 65kg dumbbells
4kg - 80kg kettlebells
dip bars
many chin bars
7 flat benches
2 incline benches
We also have an area for rehab. We've managed to get a few first and second generation Nautilus machines from the mid to late 70's. These were designed by Arthur Jones and are the finest machines ever made. They have chains, cams and gears, no pulley and cable. They include
Nautilus Double Shoulder
Nautilus Pullover
Nautiles Multi Bicep
Nautilus Row
Nautilus Pulldown
Nautilus Pulldown behind neck
Nautilus Leg Extension
Nautilus 70 degree shoulder
Nautilus 4 way Neck
We also have a Hammer Strength Uni Lateral leg press
A ton of bars, specialty bars, 2000kg of bumper plates, Strongman implements
Plenty of stuff I've left out, so as you can see it fills up quickly
Edited by markos
  • 3 weeks later...
From what I've heard and seen, atmosphere appears to be very similar amongst all the PTC gyms.
There are a tonne of lifters ACTUALLY competing this weekend out of PTC Gyms all over. Around 90 lifters from PTC's, Melbourne, Brisbane, Sydney, Perth and Gold Coast
I think one of the reasons the franchise has worked so well is that the clients all progress quickly due to everyone having a goal. We have picked up 30 clients in the last month since moving.
We had a 17yo come for a look recently, trained elsewhere. He watched Conor squatting 240kg, I mentioned they were the same age, he was blown away.
Same thing happens when girls come in, thinking that heavy weights makes them huge, they then see Vicki, Sussy, Nina, Rebecca or Heidi out deadlifting most men and all weighing around 60kg
Its an eye opener when you first walk into a PTC
  • 3 weeks later...
Had my Novice Comp on the weekend, 11 lifters, only one had competed before, a Novice Comp 12 months ago, Joe Pavone
Daniel Kranitz - 17 - 76.6kg - 105/75/150 - 330kg
Jason Wu - 19 - 73.5kg - 105/90/165 - 360kg
Brett Daly - 21 - 58.9kg - 135/100/130 - 385kg
Martin Patience - 48 - 74.9kg - 140/100/160 - 400kg
Justin Bigornia - 21 - 65.9kg - 130/92.5/177.5- 400kg
Rico Adhitya - 20 - 70.8kg - 142.5/107.5/170 - 420kg
Joe Pavone - 29 - 81.4kg - 140/105/185 - 430kg
Arthur Krasicki - 25 - 95.1kg - 155/100/200 - 455kg
Jason Chieng - 27 - 75kg - 185/130/215 - 525kg
Simon Light - 36 - 134.8kg - 185/115/245 - 545kg
Alex Deken - 21 - 89.1kg - 210/160/230 - 600kg
Read more: http://www.prorawpowerlifting.proboards.com/thread/1861/ptc-july-novice-comp#ixzz2Z57tJNFU
Interesting thing about Joey, big talker, trained at PTC for 3-4 sessions, a few of his mates lifter here, bought a crowd to watch him. A year after his first comp he comes back to see how much he's improved. Nothing, zero. Trains at FF South Yarra.
I pointed out to him Alex beat him by 170kg and Jason is lighter yet still beat him by 95kg, both boys have been here about 7-8 weeks.
Now wants us to do a program for him...........its not the program girlfriend.
Thing is at FF he is "strong", he didnt like it here, guys in his class total 250kg more than him, pretty embarrassing, IF you have an ego.
The guy is straight on FB this morning telling all his clueless friends how well he did.
Guys like this dont train at PTC nor do they ever improve.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
