Powerlifting
markos
 Share
Body just a bit off on the breathing/hold timing and bingo it's lights out. On top of getting light headed , I used to get an occasional blood nose when I was doing heavy stuff back in the day but, apparently it's normal. Or at least I was told it's ok?
A mate of mine likes to do sumo; has recommended it often to me. He says it feels more autonomous to him; he doesn't have to think about his technique as much to do the lift correctly/safely. Still doesn't lift as much as me though :P
Well I gave Sumo a shot today to see if it pisses off my lower back like regular deadlifts always manage to...nope, absolutely no pain at all. It removes a lot of load from the lower back and send to hand it off to your legs lol. Managed to do better today than the last time I did regular deads.
Will definitely be doing Sumo deadlifts from now on, though I'll still get to sorting out WTF is wrong with my regular deadlift.
Its strange how many think sumos are easier than conventional.
The biggest deadlifts in history are all conventional
Benedikt Magnusson, Andy Bolton both over 1000lbs, Konstantinov, Koklyaev over 900lbs, even here in Oz Odell Manuel 400kg, George McLaren 375kg.
There is no doubt though that some are more suited to sumo. Here in the gym we have 2 guys pull 300kg conventional, Martin should be next and he has switched to sumo, Dan has 290kg conventional and Roger has pulled 300kg but not in a comp, he too is conventional
Wasn't Martins choice. His deadlift had stalled and Max decided to try sumo. Max also noticed that Martin had stopped front squatting.
Up until Nats, Martin trained himself, he went into Nats with the 2nd highest total at PTC, came out with the 7th highest, all those in front had been trained by Max, so he asked Max to train him.
His results will be skewed by the fact he has added bodyweight, so were not going to sit here and make outlandish claims BUT he went into Nats with a 685kg total and went 687.5kg in the same weight class.
First thing Max did was to get Martin front squatting again and to have a program for him. I think Martin will go close to 730kg at ProRawFive.
The reason Max switched his deadlift was to take advantage of his levers, Marty has long arms
He is currently the only PTC lifter doing Sumo
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
