Cheers. That's what I squatted at States earlier in the year (with wraps). I should squat around 230kg on Saturday which is a decent improvement seeing as I sat out for a few months with a bulged disk in my back.
I'll take 225kg on my second and depending on how it moves I may go for more than 230kg.
FULL RESULTS ProRawFive
80kg class
1. Greg Fraser - 79.6kg - 265/140/265 - 670kg
2. Les Grills - 74kg - 220/155/250 - 625kg
3. Allen Ozdil - 78.6kg - 225/135/250 - 610kg
4. Jason Chieng - 73.6kg - 215/130/235 - 580kg
5. Eddy Hady Darg - 79.2kg - 200/110/260 - 570kg
95kg class
1. Martin Nguyen - 93.2kg -300/175/320 - 795kg
2. Jesse Burrows - 95kg - 305/175/285 - 765kg
3. Joel 'Beeker' McCaughan - 93.8kg - 285/182.5/270 - 737.5kg
4. Adam Lam - 94.3kg - 245/142.5/240 - 627.5kg
110kg class
1. Daniel Green - 109kg - 385/237.5/380 - 1002.5kg
2. Jackson Murrie - 107.6kg - 350/195/310 - 855kg
3. Albert Ozdil - 106.6kg - 302.5/180/302.5 - 785kg
4. Conor Zyskowski - 98.9kg - 260/135/265 - 660kg
5. Lee Gamble - 98.6kg - 245/120/260 - 625kg
6. Nick Haralambopoulos - 106.5kg - 240/135/250 - 625kg
110kg+ class
1. Brandon Lilly - 149.4kg - 345/265/347.5 - 957.5kg
2. Luke Poli - 139.6kg - 330/215/310 - 855kg
3. Jack Pollard - 155.1kg - 317.5/205/320 - 842.5kg
4. Zachary Turner - 155.2kg - 350/220/270 - 840kg
5. Adam Mazzon - 123.6kg - 275/170/335 - 780kg
6. Daniel America 126.2kg - 285/185/300 - 770kg
7. Zoran Jankovski - 114.3kg - 280/160/285 - 725kg
Womens Results - Glossbrenner points
1. 466.82 - Iryna Piatrovich - 505kg@65.2kg
2. 406.02 - Yolandie Weir - 340kg@47.2kg
3. 369.03 - Heidi Stewart - 390kg@63.3kg
4. 359.32 - Sussy Kollen - 357.5kg@58.7kg
5. 354.27 - Alana Andrews - 300kg@47.9kg
6. 353.68 - Rebecca Gleich - 370kg@62.5kg
7. 347.42 - Jessica Lilly - 472.5kg@93.5kg
8. 340.46 - Joanne Greagen - 362.5kg@63.9kg
9. 336.46 - Melissa Knight - 307.5kg@52.8kg
10. 329.45 - Vicki Jewson - 330kg@59.2kg
11. 310.76 - Frances Fitzpatrick - 370kg@74.5kg
Martin was set for 800kg, but then he missed his opening bench. Powerlifting is about winning, not PB's etc. Max erred on the side of caution because Jesse Burrows out squatted Martin. If Max had gone up to the planned 175kg second, and Marty missed it, he could have bombed. So 795kg it was, a 107.5kg PB from Nats.
If you guys remember, his total went up 2.5kg from States to Nats, so he decided to have Max coach him. Check out Marty's old squat and dead videos, check the difference in technique. Up until Nats Marty trained himself, now he wont wipe his ass unless Max tells him to.
Marty is going to lift in the 100's next year
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
