  • 3 weeks later...
I'm going to a bench press seminar tomorrow hosted by Nathan Baxter at my new powerlifting gym. Very excited, but also not sure what to expect. I'm hoping to learn some tips and tricks; possibly readjust my technique as I have issues with keeping my knuckles pointing to the ceiling, and get back to my pb anyway! :)
just realised your post was old. how was the seminar?
Hey Nick, it was amazing. Nathan Baxter is a huge wealth of knowledge and quite funny!
He pointed out my bench grip is too close together and I'm using a lot of my triceps. At first, the wide grip felt horrible and I couldn't bench 40kg without help from my spotter. However; after a few goes I was easily benching 42kg for reps. He also gave me some great tips about crushing the bar on the way down, and focusing on keeping the pinky finger tight!
I got the most of the deadlift tips and tricks though. An important technique he taught us was breathing in and pushing out your stomach before lifting. I don't have much of a stomach to push out, so he suggested I use a belt. I'm also having my knees too far forward in my setup; hence all my knee bruises. He suggested when I set up to keep my legs straight as I bend down to touch the bar; only once I have touched the bar with my hands should I bend my knees. He had some great cues, which I think will be beneficial to me once I'm used to them. Deadlifted a pb of 102kg at the seminar anyway :)
I have now joined Dungeon Powerlifting in Bunbury, WA. I have my run through and programming session with the strength coach tomorrow. Hopefully you will be seeing bigger numbers out of me soon!
its amazing how much difference a proper set up from the top down can help your deadlift. I still need a fair bit of work on my technique which is why im going to join PTC canberra in january. Hopefully all 3 of my lifts benefit a bit.
PTC don't do speed/dynamic days
All good Mitch, just means your getting nice and tight and using leg drive. As you get stronger you'll be able to press the same amount and keep your ass down.
Also squat more = bigger ass... harder to get it off the bench! haha
  • Like 1
  • 4 weeks later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
