HKS in japan have a supercharger fitted to an RB26 that they display in their main showroom. Because the turbo's aren't sequential, the supercharger does a great job of spooling em real fast in the lower RPM and gives a good torque increase. It looks nothing like the SC on that engine though.
mmm RB26 + HKS Supercharger + HKS VCams + T51R SPL BB mmmm creamage....
Blitz also make a supercharger system for the RB25 I believe.
There's also a malaysian mob that have been making a supercharger kit or something for the RB24C (carby engine) since 1991.
