Pros:
They are stronger
Cons:
They cost more to buy
They cost more to rebuild
They are generally heavier to use (so for a car daily driven, you'll need a big left leg)
So unless you are after 450rwkw+++ you really don't need to go bigger than a twin, they are tried and proven whilst still maintaining reasonable driveability... Especially so if you get a Nismo Coppermix, they are excellent and feel like a single plate. If you get the Comp grade one it'll hold 450rwkw no drama as well.
My triple plate Exedy was far to brutal for the street and a standard gearbox, stalling all the time and it had way to much bite.
I smashed 3rd gear on a low tune setting the very first time I gave it some stick, I'm now running a Nizmo coppermix and its like driving a different car.
Pros:
They are stronger
Cons:
This x a million!
I'd you're not after more than 800 HP, this IS the clutch to buy. Those who have one understand!
ive got an os twin plate atm, non genuie clutch plates, more bite than an organic single, but not more pedal force.
will be going triple soon, as bought a box with a holinger input shaft, and came with a triple plate.
As I understand it, the clutch is the drivetrain equivalent of a fuse. So, it's like sticking a nail in the fuse box - you won't blow the fuse, but you will blow something else in the circuit.
So, if you stick a massive clutch in, then instead of a slipping clutch (fuse), you will likely break the gearbox or the diff.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
