Hi guys, i know it might be done to death, but i am looking into doing a forged internal kit in my 25 to support my 35r and supporting mods upgrades - wanting 500+ hp
Im going to presume a balance is a must???
And if so, who has had this done and by whom and what was it like $$$ wise
Thanks guys
Shelby
Edited by Motoquipewa33
https://www.sau.com.au/forums/topic/407531-forged-rebuild/
Just had my RB25 NEO done by my engine builder.
Hot Wash Block
Balance crank, clutch
Weight match pistons and rods
Bore and hone
Deck block
Grub Screws
Grub Screw crank
Fit crank Collar
Linish Crank
Check all clearances
Assemble short engine
All that came to $1320 No Parts Included. All my head work was almost double that.
Balancing your rotating assembly is a good idea!
Not sure about who you'd go through in Perth
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6497837
about 10k + or - to get a solid engine built with a few changes in the head done, it will need to be balanced by someone who know's what they are doing, and it can take up to a year to get done right, then there is the whole cooling aspect as well, it all adds up, but do it once and do it right and in the end you'll save money and headaches, finding a trust worthy workshop is also hard these day.
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6497845
yea that is hard these days.. one place has quoted me $3500 just to balance the engine.. im not sure if that included fitting the parts which I will be supplying, and fitting personally.
ive also heard that the stock rb25det bottom end is good for 450+ hp... not sure if im willing to take that chance, im not having any issues with det, or smoke or compresion.. not to sure if i should see how i go on a safe tune for a lil bit till i do some more research....
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6497852
Have you tried the seach? There is more than enough info on here to cover your everlasting questions.
Have a read, and get some knowledge going :)
The stock bottom end is ok for NO MORE than 450hp (motor, no wheels). Any more, for extended periods, doesn't seem to last.
Either way, it's a 7-10k expedition depending on how much you want to spend.
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6497861
Do all engines with forged pistons have piston slap on cold starts??? seems self defeating if you spend all that money and have piston slap on start ups , the piston rocking in the bore all the time would surely make the whole expense of it a bit self defeating, would have accelerated wear on every start up wouldnt it?
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6501993
Only ones that are put together loose to begin with. None of my motors have ever made noise on start up.
I've heard plenty of other builds over the years and most of them also do not have noise either... But there is always one every now and again that rattles it's nuts off... I certainly wouldn't be happy if that was mine
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6502551
Any (street) engine built these days with forged slugs should not have piston slap
full blown race engines built loose (ala NASCAR/Super taxi's?Pro Stock Drag cars etc) will have some when cold, but 99% of the time they have engine pre-heaters to avoid the start up wear
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6502674
my 400kw setup has cost me 20 grand and the engine is still on a stand... also i have done all the labour except for the head work machine and balancing head costed $2000 balance/ machine was like 1500 including all new welshplugs etc... prepair to fork out alot of money
https://www.sau.com.au/forums/topic/407531-forged-rebuild/#findComment-6503464
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
