recently got a gizzmo boost controller installed on a R32 with rb20det and stock turbo, wanna run on 12psi and dont really know how to deal with the duty cycle on the boost control....what do people normally set on?
on my apexi, i have the boost and duty cycle done and was on the dyno, that was for forth gear..which is where the base should be..
would get best results on a dyno..
on my apexi i can do adjustments for each gear , so you add say +10 at a time and see how it responds, best to ramp it up with the duty than have just a flat line.
Edited by SliverS2
A slight spike is normal, better off hopping on a the motorway and pushing it in 3rd or 4th. 1st and 2nd are not great gears to be determining duty cycles.
However, a slight spike is good to bring boost to the desired boost levels quicker. I used to have my old shtbox spike to 1.4bar and settle at 1.3bar.
like i said 4th is the base, wind it up for the other gears, i have 90% for my duty upto 3000rpm, it brings it on like a cut snake.... thats for a big turbo
Edited by SliverS2
when is it hitting full boost? is that 12.75 holding or was it a spike? what gear?
i think it was just a spike....i was on the 3rd gear and it rised up to 12.75psi....but after that i tried again...it was holding on 10.8
so should i use the 4th gear to test it? coz in the 1st or 2nd gear.....they rev quite fast....but i dont think they rise more than 6 or 7psi...
I have a GFB electronic boost controller, Which from my understanding is very similar to yours. I ended up taking it to tunehouse to get it tuned. Its not something you want to muck around with if your not sure about it.
Need to put load on the engine to set the pressure right (duty cycle), 1st and 2nd are completely unsuitable. On a dyno, 4th gear would be used, on a flat road 3rd gear minimum, or better yet to put load on an engine 3rd gear uphill.
Once duty cycle is set to the desired pressure, start to turn gain up by say +5 each time until it starts to spike past your desired boost level, then either back the gain off slightly or back off the duty cycle slightly. It's completely trial and error. If you set say 12psi on a hot summer day, expect the pressure to get to 13-15psi on a freezing cold night.
I live near long deserted country roads with no speed limits so finding a flat straight road is no problem when I tune my Gizzmo MS-IBC. If I had a dyno I could probably tune a Gizzmo EBC in about 15 minutes, so maybe look at getting it dialed in at a workshop with a dyno. Much cheaper than loosing your license over.
its a tedious process.. if it were done on dyno in forth then you can just do simple adjustments on the road for the other gears, keep raising the duty till you get the boost right, then have someone watch the guage under full throttle and tell you if its holding or if its spiking/bleeding off
once you know exactly when full boost is eg.. 10psi at 3000rpm and holding steady to 7000rpm,
then simply up the duty up in the first 3000rpm, eg 90%duty upto 2500rpm and bleed the duty off to whatever worked for after 3000rpm.. that will give you the best ramping possible...
Be careful though, get it wrong and you'll blow that stock turbo up!!!!!!! :domokun:
thanks everyone....i ended up brought my 32 to the workshop and run on the dyno....they set it on 55% and stays on 12psi steady til 7000rpm....
but should i increase the boost or the duty cycle when im driving up the hill? coz sometimes im afarid to keep my foot on the throttle all the way up the hill....
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
