GTR is up for sale.
Kilometres 117,914
Modifications as follows.
Custom effects paint job
N1 rear lip spoiler in carbon fibre
Custom carbon fibre bonnet
19x9.5 Work Meisters S1 alloys
Nitto track slicks and street tyres included
Front Trust 355mm 2 piece rotors and 6 piston calipers
Carbon Ganador side mirrors
R34 GTR front seats x2
Alpine touch screen audio player with ipod connection. Alpine type R rear splits MB quartz front splits.
Apexi power FC with mounted hand controller, Greddy turbo timer, Blitz dual stage boost controller.
Garrett GT2860R-5 ball bearing turbos fitted, with stainless twin exit dumps.
Custom 3.5" full exhaust with 2 different rear muffler options included.
Sard 750cc fuel injectors
Sard high volume fuel pump
Adjustable cam sprockets
Trust pod filter kit
Trust front mount oil cooler kit
Split fire coli packs
HKS spark amplifier
Greedy strut top brace
Cusco Coilovers fully adjustable
As you can see this is not a standard GTR and there has been alot of money spent on this build. Car comes with custom plates, RWC, and a heap of original parts that came off the car during the build. All dyno tuning has being done by Ben at Racepace, and car make 330kw safe tune on 18psi with plenty more to give. Car has only travelled 5000k's since mods carried out. This car has always been garaged and driven only in good weather. Car is rust free and one of the cleanest examples out there. Genuine reason for sale.
Reg expires NOV 2012
RWC supplied
Damien 0422 288 064
PRICE $34,990
post-48812-0-80645300-1345594039_thumb.jpgpost-48812-0-44981100-1345594042_thumb.jpgpost-48812-0-34923900-1345594044_thumb.jpgpost-48812-0-47528900-1345594046_thumb.jpgpost-48812-0-17201300-1345594049_thumb.jpgpost-48812-0-65377200-1345594051_thumb.jpgpost-48812-0-12676700-1345594054_thumb.jpgpost-48812-0-39752400-1345594057_thumb.jpg
https://www.sau.com.au/forums/topic/407552-vic-1992-blue-r32-gtr/
  • 2 months later...
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
