Hey Guys,
Getting rid of some stuff, PM me if interested as i tend to lose my FS threads :P
First up -
275 40 18 Falken tyres x 2, look to be in good condition with plenty of tread, slight wear on the middle and shoulders but still good -
Price $120.00
Second -
R34 GTT standard airbox with Apexi panel filter -
Price $180.00 (Currently at a mates place and he is pretty busy so it may take a few days to get)
Third -
R34GTT engine cover and brackets etc of my engine -
Price $40.00
Fourth -
R34GTT 310mm front rotors, were supplied with car so not sure of condition -
Price $5.50 so i can buy a Schooner :D
Fifth -
R34GTT stock swaybars, maybe upgrade for earlier model (no idea) both front and rear in good condition -
Price $100 for both
Sixth -
2 x 5pt Drift harnesses new in bags, purchased them with the cage bit will not be using them anytime soon -
Price $250 for both
Seventh -
R34GTT turbo exhaust manifold and shield etc -
Price $50 (will see what i can find in terms of heat shield etc as i wont be using them)
Couldn't be bothered typing up anymore so i will post up the rest when i get some motivation. Located in Raymond Terrace. Pick up only unless otherwise arranged.
Cheers
Mat
PM preferred please!
  • 3 weeks later...
Bump it up to the top ANNNNNNNNNNNNNNNNND lets add some coilovers -
R34GTT TEIN Coilovers, have been in my car for a few years and been great..... Rears started to leak and require overhaul (Quoted $195 per side through Fulcrum)....... Sell for $400.00
Purchase them for $400.00, get the rears rebuilt for $390 and have a nice set of coilovers for under $800 :woot:
General condition is good, will remove them this week when i fit my new ones, was going to get them overhauled myself but am changing all my suspension to black and couldnt be bothered spraying them too.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
