Fs: Hel Braided Rear Lines, Catco 3" Hiflo Cat, Sony Xplod 4Ch Amp, 12" Sub, Blitz Dd Bov, R34 Gtr Carbon Wing Blade
clearing out some stuff...
*HEL braided rear brake lines suit R33 GTS-T (maybe R34 GTT?) BRAND NEW in box (only used the fronts) - $40
*Catco 3" hi flow Cat with no flanges as they have been cut off, honeycomb in good nick, no broken pieces or rattly shit inside - $80
*Sony Xplod 4ch amp (will get exact specs and watt ratings over the weekend but was enough to power a 800W sub perfectly) - $60
*12" Clarion subwoofer 800W, minor scuff marks on cone but not ripped or torn - $60
**buy the amp and sub together for $100**
*Blitz DD blow off valve, universal hose adapter style flange - $50
*R34 GTR carbon wing blade left over from the group buy $80
*R33 B Pillar carbon covers (use 3m tape or sikaflex to stick them on over the original pillars) left over from the group buy $80
will update this thread as i find more stuff to clear out
located near Liverpool Krispy Kremes NSW,
prices are for pick up, will post at buyer's expense. may be flexible on price on some things but prices are already low and cheap as it is.
Pm for any queries.
Cheers
could you send me some pics of the brake likes and the cat. interested in both.
cheers
PM me KCV.
all PM's replied
also have S & R series solid Subframe collars, BRAND NEW $50
looks exactly like these
also got for sale an apexi metal pod filter shield suit apexi pods (may fit other pod filters of same/similar size)! after $30 + post.
**metal shield in bottom right corner of picture
Had a guy who was interested but haven't heard back from him so yes they are still available.
Pics of carbon wing blade can be found in the group but section from my first group buy. It isn't a direct fit hence why the price is so low, pics and instructions on what's needed to fit is in the thread.
PM'd
If blade doesn't fit with standard endcaps, then I'll withdraw.
I read your Post #81 in the link & understood that this does fit within the endcaps - hmmm hope so...
Thanks dori
Hi Terry, with the standard End caps fitted, it is unfortunately a few mm longer, easiest fix would be to shave down the ends of the wing blade a few mm each side so the end caps can be used..
measurements below:
Carbon wing blade : 130.8cm
Original OEM blade with end plates: 131.3cm
Original OEM blade without end plates: 130.3cm
End Plates: 5mm each
so they are approximately 5mm shorter/longer with/without end plates.
More info here
http://www.skylinesaustralia.com/forums/topic/390222-carbon-goods-for-r32r33r34/page__st__200
Cheers
I had a look at the link Dori. I'd still like to use the OEM end caps, so what would you use to safely shave off 5mm without mucking up the edge?
Ta
Hey Terry,
only 2~mm on each side will need to be taken off to perhaps on a belt sander or something, i am not sure lol
best speak to your panel beater and see what they recommend :)
dori34, I'll take the amp if you will do $40 pickup this weekend (I'm assuming you still live in Cabra?)
  • 1 month later...
Yo Dori, I know this is old and your all homo with your family car now :P But any chance you still have those rear lines? (Cant see it saying sold anywhere??)
BUMP
3" hiflow catco co SOLD
Whats left:
also have S & R series solid Subframe collars, BRAND NEW $40!!!!
*Blitz DD blow off valve, universal hose adapter style flange - $30!!!!
apexi metal pod filter shield suit apexi pods (may fit other pod filters of same/similar size) $20!!!!
R34 GTR Carbon style wing blade - requires minor modding to fit - more info here http://www.skylinesa...4/page__st__200
$80!!!!!
  • 3 weeks later...
  • 1 month later...
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
