Hi guys, this is james, 200sx (silvia) owner from the UK. Got a rb25det to fit in the car and came here for some advice as this forum seems very knowledgable.
Please look out for some threads with stupid questions, i want to spruce up the engine a bit before it goes in the car.
All the best from sunny England!
https://www.sau.com.au/forums/topic/407626-noob-from-the-uk/
Welcome!
Remember to use the search function for any question you might have as there is a good chance it has already been covered. That should prevent some stupid questions being asked :thumbsup:
+1
with the search function, also use less words, for example: rb25 s15
will net a higher return then typing in rb25 into s15 conversion.
hope you find what you're looking for.
also, welcome, and enjoy your stay.
also, pics of car?
Thanks guys! Dont worry im not a noob to forums, i know how annoying it is having the same questions asked over and over.
Yes some do say it ruins the handling of the car, some say they prefer it. But that's a whole kettle of fish I don't plan on opening! As long as its quick enough to scare the crap out of me il be a happy camper.
fair enough brah
and yeh.. SRs sound shit.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
