G'day Iv joined skyline Australia hoping to sorce some information on a car I'm looking at wanting to buy .It's a 1999 tommy kaira 25r . I don't know much about skylines and just wanted to find out if it will hold its value or be worth more in years to come . I can buy it for $20,000 . Iv been told that there is lucky to be ten of these skylines in Australia . True or false ?
https://www.sau.com.au/forums/topic/407632-tommy-kaira-25r/
From reading off the GTR Owners Club (GTROC) a forum member has one.
He being one of the owners of the 163 Tommy Kaira 25R's built.
Due to it being a rarity, $20,000 would be about the going price (GTR would be a different price)
I'd say it would hold it's price but could be justified to have a higher value for years to come.
But must be kept in a mint condition.
https://www.sau.com.au/forums/topic/407632-tommy-kaira-25r/#findComment-6499878
Have a search on here for what the compliance plate codes mean
If its manual it could have had a conversion done which means its no longer original and not worth as much IMO.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=395971
If it looks like that it's a good start anyway
https://www.sau.com.au/forums/topic/407632-tommy-kaira-25r/#findComment-6500391
Finding information about most niche Jap performance gear from the late 90's early 00's on the net is pretty difficult. There's a page on the 25R in HyperRev 37 (GTST/GTT no.2) and an article in the Skyline GTS special edition of HPI.
Quick google jp search has netted some possibly useful results.
http://blog.livedoor...s/50439440.html
http://brougham1990....og-entry-4.html
http://ajp.cocolog-n.../post-32a2.html
http://www5f.biglobe.ne.jp/~ide/car_history/car_7/car_7.html
Floating around Minkara pages should be able to tell you some stuff too.
http://minkara.carvi...tommykaira/25r/
https://www.sau.com.au/forums/topic/407632-tommy-kaira-25r/#findComment-6502039
Just wondering now (after looking at web) was gunna buy this car thinking it could make good money in years to come but now I'm wondering $20000 could be all it's worth . Also I have to spend some money on it getting tuned and tidy up as its been sitting in a shed for the past few years . If I buy it could it be a good investment in 20yrs time
https://www.sau.com.au/forums/topic/407632-tommy-kaira-25r/#findComment-6509706
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
