Hi guys,
Have this little gem for sale. Super rare now as it is discontinued.
You can change bodykits to the ztune, change wheels and lower and adjust camber on the thing.
I bought this a while back for $150
Asking $100 FIRM.
You wont be able to find another!
https://www.sau.com.au/forums/topic/407693-fs-hotworks-r34-gtr-model/
