My hr31 has a twin turbo vh45. With the new ecu and a really nice tune its making 378.9rwkw. And there is not a need for any more on the street. Much time has been spent setting up the spring rate on the coil overs and camber adj to get the power to the ground. Now i can get the whole 380rwkw to the ground from 3rd gear. It is stupid fast.
That is awesome bro. I can only imagine how fast that thing would be
to be honest man, I would be content with 300kw at the wheels. no more than that. as it is, its quick, but not quick enough to be content.
Tomorrow is the day I get a power tune done. will update you guys :)
Back when everyone mainly ran 98 300kw was considered a fast power that everyone wanted now with e85 in the picture 300kw now is like 200kw used to be its nothing special with most people at the power level now its 380 plus being considered fast.
dude am I reading this correctly?
you've got a built engine but only standard injectors?
If so, you're missing out on some serious fun....
Yea man :(
short on cash. but it will be the first thing I get when I get some more cash.
420rwkw on pump fuel last year thru a auto :yes:
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
