My first R34 came with brand new Ziex, they were potentialy the scariest rubber I've ever driven on. Even on a bone dry road I'd have to be careful taking tight turns as the car would 4 wheel slide. And yes, a complete 'surprise' 360 was easily achieved in the wet.....from an unmodified n/a that's not good.
  • Replies 121
Im surprised this sort of crap can even be sold - there must be some sort of contributing factors, If they are doing this on all cars so to speak then what the hell is wrong with these people. How many of the avg joe public even know what size rubber they need let alone whats good and whats not. Too bad if granny needs to squeeze the brakes in the wet.... I believe in driving to the conditions of the road and my car, the avg person dosent, They think a car is a car, Hence will stomp the bakes, cut people off or turn corners to fast in wet and without knowing whats what its a recipe for disaster.
i know its ridiculous...i dont understand how they are still being sold ANYWHERE.
fitted some ku31s , havnt had a chance to properly test them in the wet , but in the dry they are fantastic and in slight drizzle conditions they didnt slip at all, even on boost
The KU31's are a pretty decent tyre on a budget. Had several sets; they last pretty well & grip wet & dry. Not even too noisy.
I've got Kumhos on the CX-7 after replacing the Yokohamas, this was a big move considering I've always been a Yoko fanboi. To be honest, they're quieter, grippier and wearing better than the Yokohamas and weren't as obscenely priced. Definately changed my perception of the brand.
+1
I was also a longtime Yokohama buyer; they crap on every Yoko I've ever bought.
i had ziex on 2 cars (at about the same time, since i was able to get them cheap). one were 235/45/17's on a magna, and the other were 195/50/15's on the missus SSS (stock suspension, wheels, etc). both where dead set slippery in the wet. weren't too bad in the dry, but the wet was pretty shocking. currently got toyo teo plus on the pulsar and they are much better. got some cheap nasty chinese crap on my commodore at the moment. they have more grip than the ziex did.
I'll get flamed for this but I've got 235/30/19 nankangs all around on the Z32 and so far they feel fairly good, only driven in the wet properly once with them, but it wasn't so bad.
I had Nankang S once on my 4WS 4th Gen Prelude.
> in the wet after crossing the Victoria Bridge Penrith and following a Vectra on a left hand bend, I lost control and did a 270
> unperturbed, the Vectra just drove away, still doing 60Km/Hr approx
> incensed with how these Nankangs with only 6000Km useage performed in the wet, I went to Blair's Tyres who are their agents
> Blair's rang Nankang and told them my story
> Nankang to their credit offer very good service but,
> they offered me another set of the same - Lol
> I sold the car - only because I was 'over it' of course
> told the buyer to be careful in the wet
get them to dial a little bit of camber out 1.25 is good and run some toe in on the rear i this will help traction in the wet and dry substancialy i run o.5 each side 1mm total with is more fro less grip for drifting but running 1mm each side will help a lot i could take corners at 60on a round about before mine wouls start to slip it has coilovers sway bars etc but u have to gently flow the wheel if u jerk ft or brake entering the corner or mid corner u shift the weight of the rear to the front and can cause a spin very fast .....
Since we've moved onto the topic of crappy tyres... I've never understood why people buy sports cars and then buy cheap, crap and potentially lethal tyres. What's the point of doing that when tyres basically make or break a car? There are plenty of decent mid-spec tyres available that won't break the bank and that will at least give decent levels of handling.
Tyre are consumable, other mods are considered to be more permanent.
Terrible oil will cause damage to your engine regardless of how you drive it. Terrible tyres cause control of the car to be lost at a lower threshold.
Edited by *LOACH*
falken Ziex tyres are fine... its the rear width...
I was running 17' falken 235/45's and never a problem even when they were worn out...
---front tyres wore on the inside coz of camber then were switched to the back
that said it had bilstein suspension, and always handled twice as good as stock susp.
I liked to go sideways and in the wet it was pretty fun. - did hit some oily patches of road and they become dangerous(like every tire)
wider rear tyres(265's) means less grip in the wet.... water cant get out of the tyre...
235's on the back would give you more grip in the wet.
this is on r33 gtst, 3' exhaust.
ziexs arent fine. they are terrible , and this has been proven time and time again among hundreds if not thousands who where unfortunate enough to buy those tyres.
good luck with your crashing into $hit goals of 2013
The ziex i had were 235 and they were shit, as were the 195s on the missus car, and that was the standard size. Every other tyre I've had on the missus car has been fine
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
