Bosch 040 In R34 Gtt Issue
mystery_kid
 Share
Hi
i have installed a bosch 040 in my r34 gtt it is now also wired on it's own seperate circuit
everything works fine apart from the fact that after a few minutes of the car running the pump then develops this rather loud buzzing sound and left long enough the car won't get enough fuel to boost. the sound can be replicated by just started the car and letting it idle, it will happen after a while say a few minutes
if i turn the car off and start it again straight away the sound will continue straight away, if i turn the car off for a couple of minutes it will take a few minutes again for the sound to develop
when the sound is about to start i can hear like clicking/kind of slurping sounds almost coming from the pump, i'm thinking it is cavitation or turbulence with the bottom of the tank starving the pump maybe ?
this has been a bit of a saga for me over the past months with other shit going wrong so i'm about ready to buy a walbro and sell the 040 because i'm fairly over it heh
any help would br much appreciated
thanks
Edited by mystery_kid
I had this exact issue and went through multiple pumps and eventually had to remove and clean the tank.
I know that buzzing sound all too well and had identical symptoms. How sure are you that it isnt clogged?
Sure as in pulled it out and looked at the mesh sure? Sure as in cleaned the mesh and checked it isnt clogged up again after you pull it out again sure? :P
Sure as in tried a different 040 and waited for that dreaded buzzing to happen again? The last thing you want (believe me) is to buy multiple pumps to find out the tank is infact full of shit.
Have you tested the pump flow out of the car? Unigroup Eng tested a new one in mine and the flow was starved.
There's a Bosch 040 thread under Just Jap forum.
There have been issues with this pump in past batches as you will read. Although 99.5% are just fine I'd estimate.
Just Jap sent my pump and others to Melb. Czechoslovakia didn't want to know about it. Melb tested mine and said it was OK.
I received it back in my original box (as I left a special mark on it); but the special mark I left on the pump itself was not there.
Just Jap were led to believe by Bosch that it was the same pump of mine that was sent there (Melb) for testing; but it was obviously a different/new pump that came back - and that's how they honour a warranty pffft
finally someone who knows what i am talking about
you know you're possibly right, i have pulled it out and there has been some black stuff on the mesh which i've cleaned off but other times i pull it out and it looks fine - really hasn't ever looked like enough to cause the issue
anyway i have ordered a walbro from just jap and i'm going to send the 040 back to them, they will send it away to bosch - so we'll see
i have had the pump running off a spare battery in the tank before for like half an hour trying to see if there was something in the tank blocking it and the sound never happened, but it wasn't getting a full 14volts off the spare battery
either way i've spent like 4 weekends now dealing with this pump issue since the old one died to where i am at now
I too took it out, cleaned the filter (it didnt look like enough to clog it but believe me it does) as I found out myself.
If you clean the filter, put it in, and it becomes clogged again, well the problem is not the pump.
My commiserations if you end up having to pull the tank in a backyard like me :P. I ended up with just a GTR pump (almost the same as 040) but holy shit is it loud. But as long as it works, who cares :P
Have you done the fuel pump earth mod? I'm sure the 34 is setup the same way where the fuel pump won't get full power at idle. Think it's dropped down to 9v or something when idling/off throttle. I was surprised to learn about it myself so did the mod and my pump sounds so much healthier especially when priming.
Just re-read your post, nevermind hahaha.
Edited by Akshunhiro
so i put a walbro in, all fine now
i'm just going try and manage whatever sediment is in the fuel tank, i put a new fuel filter in the other week so i will check that after 1 months usage and change it if need be and just use fuel additives for a while to do what i can
tanking the fuel tank out looks like a pain in the ass that i really don't have time for now as i'm about to be balls deep in my thesis and final semester of uni
thx bros
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
