Wrecking R33 1995
Most parts available other then duck tail , ebc, and diff.
Racing logic Ultra Complex Coilovers 12kg F 10Kg Rear $800
Lenso 18x9.5 +12 Fronts Bald Rears New tyres $1200
Greddy Turbo timer $50
Speco Boost Guage $35
Alloy Radiator $100
Front mount kit black paint ruff on cooler $ 180
Rb25det long motor comp tested all with in 3 psi of each other. New Cam cover seals $1100
Rb25det Gearbox bit of grey stuff in oil when drained but drove fine no crunching etc $950
Du luck side skirts $165
Rear Pods $ 85
Rear Bar $80
5 stud conversion $700
Nismo Strut brace $160
Front guards have zip tie holes drilled $ 60 each
Front seats $90
Rears $45
Interior plastics From $ 10 just ask
Alternator $90
Ps Pump $90
Air compressor $85
Clutch Fan $ 70
Cluster $85
Carpet $ 50
Catch can $20
Coil packs $15 each
Engine loom $165
Ecu $100
Turbo and manifold $280
Split dump pipe $85
Front pipe 3 inch mild steel $ 75
Cat back 3 inch mild steel $ 165 includes cat
Suspension arms from $30 just ask
Seat belts $100 front pair
Rears $70 the the lot
Stock bov with pipe $60
Stock Injectors and rail $ 150
Fuel Tank $250
Headlights $250
Taillights $120
Ps rack $100
Dash pad $80
Fuse box loom $150
Rear Subframe $165
Front crossmember $100
Door trims $50 each
Door handles $25each
Window regs $85 each
Power window switch drivers $85 Passanger $45
Window glass $75 each
Door skins $65 each
Anything else just ask.
I can freight Australia wide
Calll sms or email
post-90277-0-05272300-1345896912_thumb.jpgpost-90277-0-20867500-1345896667_thumb.jpgpost-90277-0-89216400-1345896627_thumb.jpgpost-90277-0-09706400-1345896645_thumb.jpg
Location? if not in vic metro how much for fmic posted to 3200
Ill get a quote tomorrow but id say you will be looking at around $70ish. Im in Newcastle nsw. I could be wrong the couriers ive been using are pretty good with price.
Comp figures of the engine? What power was it making.. for how long? How many k's? Stock? ^_^
Comp was 118-121psi tested cold with my screw in comp test gauge.
Car has 138000kms on it . Only mods are Exhaust and intercooler running 10psi
Do you have the plastic that goes across the back of the boot interior that hides the tail lights? I'm interested in that cause my plastic is all broken.
Postage to 4118 is $80
Pezhead i do have that trim send me a pm
A few more pics from today.
cheap dash has glue residue otherwise good conditon $50
keen on the coilpacks s2 or 1i got a mate in newy that can pick up..... stock?
Hi Removed from a series 2 engine
quote for rear wing to 7015 thank you (no boot)
Sorry Bud sold
Hi I'm interesting rear bar it's that from factory? I'm in WA how much for all mate 0401370648 thx
Hi mate freight to you is really expensive. Its a stock rear bar with pods on the side which are extra.
I gave a quote today for a guy in Perth and a front bar from here to perth was $440. Way too much but i cant find any couriers that will do better prices on stuff to wa
mate consider that catch can sold, can you do me a price plus postage to vic 3915? let me know how you want paying, bank transfer or pay pal easiest for me!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
